Corrosion X Recommendations
Between pixels
Plan on getting some Corrosion X for my vehicles underbody/frame. Been wanting to that now for the last couple of years, but when I checked a few days ago, I realized they have quite a large selection of products. So I'm looking for recommendations on theirvproducts bestvsuited for underbody/frame applications.
HD. Works great. Spray out of a electric wagner sprayer. Thin slightly with lacquer thinner. Like couple caps full of thinner to one full cup.
Make sure frame is not already rusted or problem will be exasperated
Holding Moisture against the frame will make it rust faster.
If your going to encapsulate then you must have perfect adhesion.
What's your opinion on Fluid Film and $36 a gallon?
Thanks. I think your the one that convinced me a while back to finally give this a try. I have a cheap paint spray gun and might use it.
I use Fluid Film here and there, but find it washes always when exposed to water.
Friends of mine used Por 15 or Kbs Coatings.
I just bought a Kbs frame coating kit, apparently it is great.
I use Fluid Film here and there said:
Washing off Lanolin Grease with water is a tough task. Maybe the corrosive salt wears it off??
The nice thing is if you apply yearly or ever other year you cover any new spots.
All coatings have their +/-
I prefer one that is removable
I've tried Chassis Saver and the Eastwood Corrosion products with mixed results even with proper surface prep. Looking at this vid finally convinced my to try Corrosion X.
