Correcting negative camber
I don't have a lot of information on it, unfortunately. It's in the shop that I use, some guy just bought it and brought it in to be serviced. Mechanic who is a friend of mine is working on it, puzzled by the amount of negative camber. Me too.
I'll pass on your advice (and any other I receive :D ).
Thanks,
TJK
Trunion or wheel bearings would be my first guess.
Bent axle housing the second.
Voodoo screwing with the laws of physics my third.
Is it the same on both sides?
Any movement of the wheel if you grab it at 12 & 6 o'clock
Bob
Bob
No to both questions.
It has been hit in the front, on the driver's side. Problem is on the other side. Bruce is going to rebuild the axles anyway so plans to check the bearings etc. during that process.
Thanks,
TJK
Does it have taller springs than stock???
Cheers,
Sean
Bent axle housing is my bet.
I have seen bent housings and bent leading arms. If they get tagged just right even a "minor" hit can bend the housing.
I have the same problem in the pasenger side is like 3 deg negative and in the driverside is like 1.5 deg. negative too. l have just install 3" springs in the front and 2" in the rear.
