Correct size (metric) for Diff drain plug?
Philadelphia, PA
having a bitch getting it off and starting to strip with a 15/16 wrench. Using plenty of CRC - might have to wait a few days to let it soak in.
Also, I need to remove the skid plate to get at the tranny/t-case to change the fluids?
For all the drain plugs buy a 24mm 6 point socket and get the end ground flat on a lathe or just file it. That way you will get better contact on the plug. It won't matter letting it soak with penetrating fluid, the threads will be well lubed.
Yes you do have to remove the skid plate, mostly just to fill the tranny. It makes it much easier.
thanks. Its not the threads, but the head of the plug that seems rusted to the diff. I got the front off easy enough but the rear is the prob. By the looks of the black/grey porridge that came out of the front it looks like the PO hadnt changed the fluids on these in a while.
I've had to weld nuts onto several 'stuck and stripping' drain plugs. I hope you don't have to, but it works if you need to get it out.
Before you actually pull them out, buy some recessed allen-head plugs and eliminate the problem once and for all.
That would be your axle seals leaking grease into the oil. Pretty common, but a bit of a PITA to fix. But thats for another thread. :rolleyes:
BTW you could just remove the bottom stud on the diff cover.... You just can't take all the grey past off the magnet on the drain plug though. It would git er done right now if you want to take your time getting the tools and parts together to do it right.
You...................... get back to your cruiser Moab is coming quick.
Test drive up on Dumont this week?
Tech, try tapping the end of the nut with a ball pene hammer, sometimes frees the locked part.
Last but not least, little heat and a six point on a air gun which gives that hammer affect which always works for me.
Welding the nut last attempt.
I forgot about hammering, but that usually happens on a rock when your wheeling and then you mysteriously loose all your diff oil shortly after. :D
Oh and Radd I just stepped away from the traction bar for a second, get off my case already. Dumont? Maybe..... wife would KILL me if I broke something this close to Moab... I'm not allowed to wheel with Too Tall till then. :bounce:
Sorry for the hijack, but someone has to keep Radd in line, he's been sniffin too much stinky diesel exhaust.
Magnetic Drain Plug W/Washer - $3.75
OEM Toyota Drain Plug With Magnet
(Fits 58'-1/90' Manual Transmissions, 58'-1/98' Transfer Cases, 58'-1/98' Differential Drain Plugs)
Part# EGP18021
[/endpimp] :D
I changed my Transmission/Transfer case fluids today WITHOUT removing the skid plate, but I used one of those pumps 'n tubes that you attach to a gallon of gear oil. I don't think I'd go this route filling from those quart bottles! It's a bit messier job with the skid plate on, but I had reasonable success leaving it on.
Yeah, I took the skid plate off and had one of the six bolts break - not too bad. There was alot of junk on the skid plate I was able to clean up.
By the way, I got the drain plug loose, it is actually the FILL plug that is the bitch. Might resort to heating up the differential and cooling the plug to see if that works.
Bit of a Hi-jack - when I had the skid plate off I found a cable coming from the bottom of my tub with an aluminum(?) probe on the end. It was just hanging there like it was some kind of temp measuring device. Has my truck been abducted by aliens or is this some part I have no clue about? any ideas?
