Correct (or best) rear panhard correction?
RDU, NC
I am not looking for a specific product or manufacturer, but am curious about the collective wisdom on this. Been doing a lot of reading and trying to decide what is best..........
There are 3 options of which I am aware:
1. Panhard drop from the frame bracket.
2. Higher panhard bracket off the axle housing.
3. Lengthened: cut & welded, retubed, new longer panhard.
(For this discussion, eliminating links / re-engineering the suspension is not an option.)
In an effort to preserve every day ride quality and stability, and to maximize the cycling of the rear suspension while offroad, which solution is either "correct" or best? or does it just not matter, so long as something is done to compensate for lift?
im running heavies and while the axle shift is noticeable, theres no noticeable effect on driving. i think proper castor correction would have more bearing on on road stability and ride quality. like landtank said, not really needed until you get into higher lifts. but my choice would be weld in adjustable setup...
The best option would be to keep the panhard rod as parallel as possilble to the axle. Either a drop or axle braket, the most important fact is that the mount is solid. There is the possibility that an axle bracket can hit the body under compression.
Now my opinion, just install an adjuster. I have Slee 6" rear springs and never had any issue with only an adjustable panhard.
