Cornucopia of Codes
Yokosuka
Finished up some work on the 96 over the weekend and hop in to head to work today. Halfway there, CEL pops up. Quick scan revealed the shown.
P0021, CAM Position A too advanced
P0051, O2 Heater Control Circuit
P0101, MAF Circuit range / Performance
P0226, Throttle position Sensor Switch circuit performance.
I was quite surprised as its running perfectly fine, and these seem to be unrelated to an extent.
I attempted to clear the codes, both engine on and off, but no joy.
Work completed this weekend was rear heater delete and rear bumper install. Only things I can think of are that some coolant dripped from the heater onto the O2 sensor and that I was leaning on the air intake tube just a tad while bypassing the hoses under the hood. Visual inspection looked fine.
Anybody have any ideas? Wiring harness? ECM?
Thanks guys.
Probably got the rear bumper tangled up into the head gasket and it's going to need top to bottom work.
Beyond that, I am striking a blank as to how all of those things are related. I could see if coolant somehow getting on the MAF and the O2 sensor, but the throttle code is a new one for me, but I have the earlier model, so I am afraid I can't be of much help beyond this.
Bad ground somewheres. That’s what happened when I had this similar code cornucopia. Turned out that the ground wire was put back improperly. Easy fix if it is.
This would be nice if true. Any common faulty grounds out there?
This is the one that was the problem for me when I did my rear heater delete and heater control valve swap. It was mistakenly put back over the plastic piece instead of under.
Awesome, I'll check it out in the morning.
I didn't remove that ground, but was definitely working around it the entire time.
@Aloha Jen Soooo you're awesome. Not real sure what happened with the ground wire, but i removed and cleaned it and all the random codes went away. Kalapawai Market lunch on me next time I'm Kailua.
Unfortunatley I was left with a P0135 Code which is O2 Bank1 Sensor1 so I replaced it with a Denso.... but no joy. Currently still popping up after about 8 miles of driving. Scanner shows good communication, so I'm back to the drawing board.
This was NOT the sensor that fluid dripped on, still wondering if there was an ECM wire that I rubbed through some where. Any ideas?
IIRC, that code has to do with heater draw, or lack there of. Put down the fancy scanner and pickup the DVOM, likely a bad connection somewhere in the circuit?
You're correct on the code: "Sets when O2 Sensor heatr current is over 2 amps or under .25 amps, or circuit voltage exceeds 5V during operation"
Most P0135 are fixed by simply replacing the sensor, but now I'm also the boat of bad connection.
Was planning on Thomas Mountain this afternoon, hoping for a quick fix, not happening now.
Thanks guys.
