Core Support Replacement?
jynx
Turd Herder
Eagleville, TN
Anyone replaced the Core/ radiator support on your pickup/4runner? Mine is in pretty rough shape. It is crooked enough that I can't replace grill or headlight buckets, radiator is in with a spacer to keep it from being in a bind, etc. So since I am working up to dropping in a fresh motor soon, I was thinking of going ahead and doing this at the same time.
I have a OE core support that I cut out of a salvage yard truck. Front was straight and I got it plus a little bit of the inner fenders, so I know I need to drill out the spot welds and have some other prep to get it ready to go in, but how hard is it to actually make the change out. I have read of a few folks drilling things and making the core support a bolt in unit instead of rewelding it and I like this idea and will probably go that route.
I know removing the core support will make getting the old engine much easier to get out and then I could put the new one in after the motor is in.
Anybody got any good pictures or know where to find a write-up of the process?
Thanks in advance. :beer:
Matthew
Take a propane torch and a wire brush to both core supports. Burn the paint, then brush. That will show you every spot weld.
Take a drill with a 1/8" bit, and drill a hole in the center of every spot weld you need to break. Then, follow up with a larger bit until the weld is gone. Since you've already burned off any paint and seam-sealer, the panels will just about fall apart.
You can use a hammer and old screwdriver if you don't have an air chisel, to finish the job. I doubt you will need either.
Try to keep the new core-support as one big piece. That will help keep everything aligned like factory.
You can PM me if you have questions.
Roy
There are about 40 spot welds to drill out. Get a spot weld drill bit from an auto body supply source. I ordered one from Eastwood.
Thanks for the tips. I will practice on the new one first. I got it as a single piece out of the donor, unbolted it and then cut the inner fenders so I will have to remove the inner fender remnants anyway. I will definitely keep it in one piece.
If I am planning on bolting it back together is there a good size bolt you'd recommend. Toyminator I know when you did your second one you made it bolt on. Is the spot weld bit worth the $ vs a drill bit? Just curious since I am looking at 80 or so of these little buggers to drill out.
Also, did you bolt every hole back up, so 40 total bolts on it?
Yeah 8 or 10 on each side is fine. I actually welded the nuts to the sheetmetal, then ran the bolts in. They don't need to be very big.
I used the spot weld drill bit from the front side of the support I took off and the back side of the donor so there were no holes in the pieces I needed. Then drilled holes the exact size of my bolts and was able to put them exactly where I wanted. A regular drill but will get the just done just as quick but the right spot weld bit makes it look cleaner.
What size drill bit do I need to get? 1/4"? I found a 3/8" double sided bit, but that may be too big if I only need 1/4" bolts. I will probably use metric bolts.
I also vote for getting the special spot-weld cutter bit. They make a much cleaner round hole, whereas a twist drill will tend to distort the "good" metal you're trying to save. It will also leave a nice "dimple" in the metal underneath for making your pilot hole. Use even pressure, good cutting fluid, not too fast with the drill. I bought a solid carbide one, I think I found it at Jegs, and it did a great job. The one Eastwood sells is also really good, but I think it's actually the same thing.
http://www.eastwood.com/spotweld-drill-3-8-pro.html
