Cooling System Rebuild Part Numbers
Azle, TX
There are several threads going on with different titles and various states of information. I thought I start another one with a good title so it can be found easier in the future. Hopefully, I'm not duplicating something, but you get what you pay for.
I did find (the hard way) the Toyota parts diagram lists the incorrect clamps for the upper heater tee hoses. Correct parts are listed.
The rear oil cooler hose is a particular SOB. Just plan on cutting it after you get the clamp off. I spent more time on that one hose than the rest of the system combined. I did choose to NOT do the lower rear heater hoses. They look perfect and I chose to leave well enough alone. They do not look hard to change.
Partsouq is by far the best place to get these, although they seem to have a hard time keeping the main radiator hose clips in stock.
8724860460CONNECTOR, HEATER WATER HOSE (Heater Ts)2
1628250040HOSE, WATER BY-PASS, NO.51
1577750030HOSE, OIL COOLER1
1628150030HOSE, WATER BY-PASS, NO.41
9046720011CLAMP OR CLIP(For front bypass hoses to oil cooler)8
1626150090HOSE, WATER BY-PASS1
9046713054CLAMP OR CLIP(Small diameter hose 090)2
9613652101CLAMP OR CLIP(Lower T hoses)4
872456A210HOSE, HEATER WATER, INLET B1
872456A180HOSE, HEATER WATER, OUTLET A1
872456A201HOSE, REAR HEATER WATER INLET, A(FROM ENGINE)1
9955620200HOSE, HEATER WATER1
872456A220HOSE, HEATER WATER, INLET A1
872456A190HOSE, HEATER WATER, OUTLET B1
1657150150RADIATOR, NO.1HOSE,1
1657250150HOSE, RADIATOR, NO.21
9046743002CLAMP OR CLIP, HOSE(FOR RADIATOR INLET)1
90466-41008CLAMP OR CLIP(FOR WATER HOSE)3
9613642501CLIP HOSE (Upper T hoses)8
1629550060HOSE, WATER BY-PASS, NO.71
872456A090HOSE, REAR HEATER WATER INLET2
9955620200HOSE, HEATER WATER2
9613642501CLIP HOSE (Additional for rear heater hoses)8
9091603100THERMOSTAT1
1634650010GASKET, THERMOSTAT1
1640167150CAP SUB-ASSY(FOR WATER OUTLET)1
I'm fairly certain this is everything. I ended up getting parts from a few sources, unfortunately. Your mileage may vary, check the prospectus before investing, past results are not indicative of future returns...
Couple of things that look different from my list, and looking back at the parts diagram I think I understand why.
1. 87245-6A060 and 87245-6A180 are both listed as HOSE, HEATER WATER, OUTLET A. The difference is the former is "UZJ100" and the latter is "UJZ100 W(REAR HEATER)"
2. Likewise, 87245-6A070 and 87245-6A220 are both listed as HOSE, HEATER WATER, INLET A. Again, the former is "UJZ100" and the latter is "UJZ100 W(REAR HEATER)"
Looking at your list I see 87245-6A180 (from point 1 above), but neither of the latter (from point 2 above). If you hover on the parts diagram, it highlights the pairs in gray and if you click on the parts diagram it asks you to choose rear heat or not. If you bought 6A180 (LC w/rear heat) then you would buy 6A220 as well.
3. I'd add if you're replacing all of the hoses and thermostat, might as well throw a $12 radiator cap on there as well.
4. What I think you've helped me uncover is the Heater T Diagram (one of the "8716:HEATING & AIR CONDITIONING - WATER PIPING" on PartSouq), if you hover over the clips on the list in PartSouq, only highlights 4 of them. But there are 6 hoses in the diagram, so there obviously should be 12 clips... so that's where the 96136-42501 for Upper T hoses (x8) and 96136-52101 for Lower T Hoses (x4) comes from on your list.
5. All in, I'm counting 17 total hoses, therefore 34 clips/clamps, plus 2 Heater Ts, Thermostat w/gasket, Radiator cap, and I'm throwing in the reservoir cap assembly (comes with the 2 hoses and clips for ~$17) and that's everything.
6. As has been mentioned in other threads, useful to get the hoses disconnected to look for pitting in the aluminum of the water inlet and by-passes so you can order all at once... if you can afford to have the Cruiser sitting for a while, or, at worse reconnect and refill system to run for a week while parts come in.
Good catch. I had a cut and paste error. Added two hoses and a radiator cap to the original list.
I'm also doing 16405-50020 (cap sub-assembly -- includes the 2 hoses and 2 clips and a new cap) because it's $17.35 vs just one of the hoses. Personal preference.
Otherwise looks good!
I ordered a new overflow tank assembly, which includes the cap expansion hose and two clips. 16470-50100
I just recently ordered as much of this as I could find (including the heater hose kit on Wit's End), but it looks like I missed a few hoses!
And beware, its likely the Wit's End kit does not have the correct clamps for the four top "T" hoses.
Thought I'd post this question here. I'm looking for the part #s for these hose clamps.
When I got my radiator replaced a few years ago by a local shop that does a lot of LCs, they used worm clamps.
Those clamps look awful ...
Good call to replace those. Here's some PN I found:
Alternator has 4 holes that the pipe attaches to. There's also other hoses around you can buy you can check the parts document, the clamps get rusted out over time. If you're reusing hoses and replacing clamps be careful when you put the clamp back on the old hose, as the old hoses have indentation over years, if you give it a new indentation spot it might leak.
Here are the ones for the water inlet pipes, in RED. You can check these from parts documentation of your model.
Here are the ones for the transmission fluid (the smaller ones under the radiator, there's 2 of them):
That's accurate. Three of the "Big Hose Clamps" are the same size, and the fourth (clamps hose to bottom of radiator) is larger.
Please replace those hoses as well, they've been cut by the worm gear -- and if they are the originals then they're due anyway.
Hi Bisho,
Just bought a new to me 99 lx470. Biggest outcome of the PPI was to replace heater T’s and hoses that are attached to them. Your summary here has been a great starting point. Haven’t been a big diy guy before but starting with this rig.
I currently have:
CONNECTOR, HEATER WATER HOSE (Heater Ts) 8724860460 - 2 heater T’s
9613652101 (CLAMP OR CLIP Lower T hoses) - 4 clips (2 per each Heater T) for hoses connecting to lower T
9613642501 (CLIP HOSE (Upper T hoses) - 8 clips (4 per each heater T) for hoses connecting both front and back sides of each heater T
The last thing I’m trying to figure out is which hoses I need for each front and back side of each heater T.
Appreciate your help! Even if you don’t manage to get back on this - this write up will certainly help get me there.
Hi Bisho,
I currently have:
I recommend going to Partsouq.com, putting in your VIN, and looking at the parts diagram. The hoses are in my list, but a few years removed I don’t recall which is which. Have fun!
I am using this thread and Partsouq to put together a list of all cooling system hoses for my 2004 LX in preparation for a complete cooling system refresh, which I figure is fairly cheap insurance against potential overheating issues given that most hoses on my vehicle are over 20 years old and some are showing signs of swelling and leaking from worm-drive clamps.
Interestingly, I am getting 18x total hoses (and 36x clamps) from Partsouq. Below is a summary of the parts that I have identified. I haven't cross-referenced against the list above to figure out where my "extra" hose is coming from, but perhaps this is a model-year difference between the 2004 and earlier 100s? The table below is organized by Partsouq part diagram number. Also interesting is that in the diagram with heater Ts, the connector part numbers that Partsouq provides for my 2004 seem different from the part numbers above; hopefully these are correct for this vehicle. Odd to me that there seem to be a few potential part numbers floating around for those clips.
As always, your mileage may vary and there could be errors in the table below, so recommend verifying against Partsouq (or other) diagrams before buying. If I find any obvious issues after ordering I will update this table.
PNDescriptionQty NeededNotes
1603: RADIATOR & WATER OUTLET
1626150090Hose, water bypass1
9046713054Clip for water bypass hose2
1657150150Hose, radiator 11
1657250150Hose, radiator 21
9046743002Clip, rad hose 21
9046741002CLAMP OR CLIP(FOR WATER HOSE)3
8716 - HEATING & AIR CONDITIONING - WATER PIPING (1)
872456A800HOSE REAR HEATER WATER INLET A(FROM ENGINE)1
9955620155HOSE, REAR HEATER WATER OUTLET, C1
9613442100CLAMP OR CLIP(FOR WATER BY-PASS HOSE NO.2)4
9046719022​
9613652101​
8724860460Pipe, water heater (heater T)2OEM brass substitute PN: 87248-95400
2211 - FUEL INJECTION SYSTEM
1629650030HOSE, WATER BY-PASS, NO.81
1629550070HOSE, WATER BY-PASS, NO.71
9046713054CLIP(FOR WATER BY-PASS HOSE NO.7)2
9613551300CLIP(FOR WATER BY-PASS HOSE NO.8)2
8716 - HEATING & AIR CONDITIONING - WATER PIPING (2)
872456A090HOSE, REAR HEATER WATER INLET, C1
872456A090HOSE, REAR HEATER WATER OUTLET, A (FROM HEATER UNIT)1
99556-20200Hose, Rear Heater Water Outlet, B1In Partsouq diagram as 87256B but not selectable. UPDATE: My 2004 does not have this part. The hard line is continuous all the way to the 872456A090 line.
99556-20200Hose, Rear Heater Water Inlet, B1In Partsouq diagram as 87255B but not selectable. UPDATE: My 2004 does not have this part. The hard line is continuous all the way to the 872456A090 line.
9613642501CLAMP OR CLIP(FOR WATER BY-PASS HOSE NO.2)8
1503 - ENGINE OIL COOLER
1577750030Oil cooler hose1
1628250040Hose, water bypass 51
1628150030Hose, water bypass 41
9046720011CLAMP OR CLIP(FOR WATER BY-PASS HOSE NO.2)6
I updated my post above but figured I'd expand a bit here too. It turns out that my '04 doesn't use 2x 99556-20200. Instead, the hard line is continuous from the lower heater T lines to the rear heater hoses by the cat shield. 99556-20200 is shown in the Partsouq diagram for my vehicle, but it is not selectable. I guess they just didn't update the drawing when 99556-20200 was no longer used. The pics below show the diagram for my '04 where "87255B" is shown but is not selectable in the diagram, and an eBay pic of what I assume is the rear heater lines for an earlier version with 99556-20200 shown (the two straight hoses in the middle of this run). In comparison, my hard lines have no junction for a hose as they go up toward the heater Ts.
On that note, if anyone needs 2x new 99556-20200 hoses for the cost of shipping shoot me a PM!
