Coolant went........somewhere.
Blackdog
"Y'all smell that?"
Next to the particle accelerator
Drove down to see the Blue Angels fly in Pensacola this weekend. Changed the oil and checked all the fluids as always when going on a road trip. All looked fine in Birmingham, but somewhere on the road I lost ALL my coolant. I noticed on the way home that the heater wasn't warming the cab, so the first place I looked was the radiator. EMPTY!!!! Never got a high temp on the idiot guage or smelled that tattle tale "Hot" smell. All I had access to for a fill was parts store coolant, so I guess now is the time to flush the system and replace the coolant. Before it all leaked out I had Toyota Red in it. The vanes that I can see through the filler are clean as new with 260k on the clock.
POP QUIZ
Where is the most likely place to look for my leak. From what I could see at night with a flash light, everything was dry around the hoses:meh:
have you replaced you phh?
You lose all your coolant and it ain't gonna run very well for very long. And if run long it will surely lose power, stink like nothing you are ever smelled and most likely cause catastrophic engine failure. Did it lose ALL or just SOME coolant? How much did you need to add? if you were able to add some and be along on your way, I doubt you lost all, especially if you drove more. If you drove, more how much and did it continue to lose coolant? Did it heal itself?
AS far as identifying where it went, look everywhere...rad, rad hoses, heater hoses, overflow tank.... Then pressurize your cooling system. Check the engine oil to see if foamy/grossly overfilled. It's gotta go somewhere. It doesn't evaporate.
What is a 'phh'?
Now I dunno who thought of this silly acronym, but a PHH is the "pesky heater hose."
Why not just call it a heater hose? After all that's what it is.
There is one that is a total pain in the ass to replace under the intake on the driver's side of the truck. That one however, is a P.I.T.M.F.A to replace and duly has earned that acronym, simply a variation of P.I.T.A. in case you're trying to determine the words.
Maybe we should go with your acronym and call it a PITMFAHH?
That one is definitely easy to overlook and will dump your coolant pretty quickly. You can see the PHH through the driver's side front wheel well up behind the starter on the engine block. Only about 2-3" long.
Since you lost coolant while driving, and you did not notice a massive steam cloud, it seems the leak must be very low in the system. Eyeballing the radiator and not seeing any could only mean a few quarts low.
But since you stopped at the parts store and refilled it - how much did it take?
From experience, you defenately have a leaky coolant hose (which one? that's up to you to find out)
I suggest to fill up the radiator with the green antifreeze / turn on your rig for about 1/2 hour and look underneath. If you are loosing coolant, I can guarantee you 2 things:
1) you will see either a drip or big ass puddle running down the engine into your driveway
This can be a coolant hose or a bad waterpump
2) If you don't see any leaks / you will hear a shhhhh shhh (sound) or smell a sweet aroma coming from your engine bay.
Which translates to antifreeze landing somewhere along the exhaust (from maniful to catalyc converter)
Do this and let us know of your findings
Thanks for the input. I am watching closely for signs of a leak. So far the radiator is keeping good level. Somewhere in a 700 mile trip I lost almost two gallons of fluid. Crazy aint it? When I figure out where it went I will post up.
Since it does not seem to consistently loose the coolant - I would look at the heater hoses foremost. The coolant does not always circulate through the heater as it does in the rest of the system and that would account for it doing one thing at one moment and another later.
I recently had a coolant leak that was almost undetectable at idle so it was hard to diagnose. Mine was much more consistent though because the truck was losing about 1 quart per 60 miles driving and never lost a whole ton at once. My leak trigged an engine light once with code P0116 (basically the temp sensor that monitors coolant for the computer, not for the fan) because I let it get too low.
I found that the leak was at the 90 degree hose right before the heater valve on the firewall. The hose clamp just wasn't doing its job. I added another clamp, and tightened them both and I've been leak free since. My clamps are just the standard screw type, and probably not whatever came on the truck originally.
Your leak sounds really strange because it seems that you lost the coolant quickly, without triggering an engine light and now you've been driving around without any noticeable loss? Is it possible for a failing water pump to consume coolant? A coworker was telling me that a leaking water pump can sometimes only leak when it reaches pressure and then it flings the coolant so that you may have trouble see it.... really going out on a limb here.
