K so I have a 95 with a new yoga block and a head that was machined at local shop. Cruiser has 185000 miles on it and engine has about 40000 since rebuild. I am smelling coolant when I exit truck after driving. There is no sign of coolant loss. I replaced water pump and phh when engine was rebuilt. I do not overheat and have no codes. There is no signs of heater core leaks on windshield or on floor boards. There is a slight miss at idle but It threw a code after I did the phh hose for a leaking injector. I believe I shifted on injector while doing this. I set injector again and cleared code and have not seen it again. I have put almost 15000 miles on it since this.
What should I check to see where coolant is coming from. Maybe compression test for head gasket? Sorry to ramble so muc.
