coolant reservoir not changing
sea bass
10 Year
6 months ago i bought a new toyota brand radiator cap from a online retailer, a few weeks ago i noticed my coolant reservoir did not increase or decrease with the motor heating and cooling it just stayed at one level,so i went to to napa and bought a stant cap for 7.99 it looks to be identical construction as the toyota , put it on and my reservoir is fluctuating again as it should be just wanted to let people know in case they run into this.
guess which one is which as a matter of fact the stant is stainless steel the Toyota is steel
I would be speaking with the "online retailer" your bought it from. It's a faulty cap or improper application no matter who made it.
I already did they're going to send me a new one I just wanted to get one quick it was only $8 i always go oem on everything ,besides the stant says it was made in Chicago
I recently put a new Stant cap on my wife's '97. I noticed the reservoir level did not change when it warmed up, but did not think much of it at the time. Promptly blew 3 hoses in 4 days. Took it back and exchanged it for another and seems to work like it should. I decided to replace all the rest of the radiator and heater hoses. Waiting on the formed bypass hose that goes to the throttle body down under the intake to finish it up.
if you give me your info I will gladly get another Toyota off of you
So the reason I bring that up is because I had an OEM cap that had a slightly oversized rubber gasket that was causing it to stick as well. Replacing it solved the issue. This was long before I started carrying them. All caps I routinely check just out of curiosity once I get them in, trying to mind another abnormality. It happens. The supply chain isn't perfect.
it
it appears to be the right size , i don't know what could really go wrong in a rad cap
it
Radiator cap is supposed to hold pressure to allow the coolant system to build a specified pressure in order to take best advantage of cooling. For every pound of pressure you exert on a closed system, at sea level, you increase the boiling point of water by 3degrees. So a 12# cap allows water to reach 248 degrees without boiling. Once that temperature is reached, and it boils, the cap is supposed to have a spring that is matched and opens to allow the pressure to vent into the overflow. If it doesn't vent, things go boom. Anywhere from hoses to radiators and sometimes headgaskets.
Heat soak can at times get the coolant to this temperature on hot days, easily. Bad cap can spell disaster.
well if you have any new Toyota caps I'll gladly get one off you well I got lucky mine was like that for a few weeks I just noticed it yesterday nothing blew no boom is good then again I keep my 80 and pretty darn good shape
In my experience Stant products are high quality. I wouldn't be concerned as long as the cap pressure is the same as the OEM one.
I agree it is very high quality it was a stainless steel body compared to the Toyota Steel I'll just get one to have a backup and to support our mud vendors
