Coolant overflow bottle relocation.
danadog
Storm Trooper
Labrador
Website
www.minipi.com
Hey guys, I need to move my coolant overflow bottle that is currently between my headlight and aux battery to a new location. I want to use its current location for a wiring distribution block and fuse block. I have searched here for possibly someone else that has moved their bottle so I can get some more ideas on possible placement and brackets. There isn't much room under the hood anymore so I am scratching my head on what to do. My other option is to possibly make a new bottle with somthing like a stainless Klean Kanteen type water bottle, but I am unsure if it will have the capacity needed for the cooling system. Pictures , thoughts and ideas are welcome.
I also thought about using the coolant bottle space for other items.
But like you, no space to put it. One thought I had was using clamping a bottle the engine side of the aux battery and getting a different shaped coolant bottle. There are lots of them available on ebay - like Samurai bottles or even as you suggested, a Klean Kanteen type. My only reservation in using a metal bottle is that with a plastic bottle, a quick glance lets you know how much fluid is in it.
I can't use the above mentioned location because I have an OBA unit.
