Hey all, 1994 FJ80 with 130,000 miles. Baselined the vehicle couple weeks ago. Coolant was flushed by dealer and new red Toyota coolant put in. When I got truck back, coolant was to full level in expansion tank. Been driving a lot, 800 miles since the coolant change and I notice the coolant level at cold is between full and low on expansion tank. Checked the rad and it is full to top in rad. Should I get a pressure test. Could be a small leak somewhere? Water pump? I also ordered a new one rad cap. Thoughts? Thanks.
You can do a pressure check, but you probably just had some air in the system. If the coolant level continues to drop with continued driving then I’d invest more time in researching.
Coolant level in the overflow tank will fluctuate with engine temperature. That is how the cooling system maintains proper level.
As long as the radiator is full to the top of the filler neck when cold and the overflow bottle has coolant in it, the system will self regulate.
If flushed and refilled, that amount of drop seen in the expansion tank seems normal. Depending on the water source, there can be dissolved or tiny air bubbles enough that they will work their way out. Likewise, with rear heat (if present) it's hard to get all the air out at once unless you idle for awhile with the cap off while parked on a slope with the nose of the truck up. That could all easily account for the drop. Keep an eye on it for the next few weeks just in case.
A new radiator cap is always a good idea if you can't remember when it was replaced previously.
