Coolant leak
canada
Hi guys, just got back from the dealer and they sent me these pics saying i have a gasket leaking and its 6 hrs of labour and $350 in parts (so like $1700 cad) to fix. This is a 2009 LX. Does this look serious to you? Water pump was replaced at about 250km (truck has 378km on it now), radiator done last year. Thoughts?
Though a while ago could it be left from the previous issues/replacements? Are you seeing a coolant loss? If you answered yes and no I would wash it off and watch for it to reform.
No coolant loss and nothing under the vehicle. I will see if I can get under there to wash it.
I would ask for clarification on source.
To me that looks like possible valley plate (heat exchanger) leak running down to back of motor.
You can pull some foam and peak under intake or snake a borescope cam in there to inspect.
Agreed.. I’m also surprised it isn’t using any coolant. Granted, it would probably be slow, but what’s leaking out has to be coming from the system and reservoir, ultimately.
You can pressure test the cooling system to get an idea of if/where there is a leak.
