Coolant Leak question searched?
I just bypassed the metal tube and replaced the PHH and began to refill and $&^# there was a leak and It Is hard to tell where It Is coming from, looks to be a smaller diameter hose under the Intake? Anyone have any input?
Clean it all very carefully, then get a radiator/coolant pressure test kit. Pressurize the cooling system and see if you can identify where the leak is coming from. Be careful not to overpressurize the system.
There is a hose under there that runs from the head to the back of the throttle body to keep it from icing up in cold weather. It could be the culprit, but I would try and determine what exactly is leaking before diving into it. How fast is it leaking out?
It Is leaking out In a steady stream as soon as I pour It In probably wasted a half gallon of 50/50 mix before I realized It was leaking! That s%$^ is expensive too!
Sounds like the leak should be pretty obvious to the naked eye if it's leaking that much and that fast. Have you determined where it is coming from? I would agree with Pin Head that the stuff you touched last is the most likely culprit. Are the connections at the top and bottom of your PHH bypass tight and leak-free? At this point there isn't much we can do until you figure out what is leaking.
Yes they are good and tight but, I did plan on tightning the one at the block again just to make sure cuz It Is so hard to get to. ASAIK there is a small diameter tube under the Intake that looks like It is coming from that but, I do not think we disturbed that hose duduring the PHH R+R. I am now thinking that this hose has a leak and made it appear to be the PHH. The PHH we removed did look like it was In a slight bind but not bad at all. The PHH was not original and had been replaced prior to my ownership and they broke and bent the tabs on the metal tube so I just chose to remove It and bypass It. Thanks In advance to any and all Information on this puzzling leak. Worley
