COOLANT LEAK {help}
NORTH CAROLINA
I have a 1996 LX450 with 160000 has anyone ever noticed a coolant leak under the intake manifold. I can see and smell coolant but the intake covers everything up, are there any coolant hoses under the intake [hope it is not a head gasket]:doh:
Sounds like it could be your pesky heater hose or PHH as it is more commonly known. Do a search and check the FAQs. Plenty of information ou there.
The hose is located under the intake manifold and above the starter.
Good Luck
I always smell coolant with both my trucks, especially when hot.
If you are concerned about the HG, do a leakdown test (different from a compression test). If you are concerned about the coolant leaking somewhere, do a coolant system pressure test.
