Coolant in oil
Corbett, OR
A few weeks back we found coolant in the oil. Suspected bad head gasket. Pulled apart. Took the head to the shop for usual checks and work. Everything tested good. Installed a OEM Toyota head gasket kit. Didn’t see any signs of head gasket failure. So, replaced all seals and gaskets for oil cooler as well. Put it all back together, compression is good. Runs good. Took it for a 10 minute drive and found more coolant in the oil.
It’s a 1FZ-FE.
Is the oil cooler bad? Just some residual coolant in the system?
Did you (or the machine shop) check the head and block (deck) for flatness, cracks in the head??
Did you get any photos of the head or block (deck)?
How were the head bolts torqued down (new/reused?)?
Maybe drain the oil and change the filter (again) then recheck??
Has it been a while since you've done a longer drive? Lots of short drives create condensation in the engine that look like water/oil mixing.
Oil cooler failure, you would have oil in the coolant, as oil pressure is much higher than cooling system pressure. If you pressure test cooling system, are you losing pressure? At any time was the cooling system Rusty? Did you also remove the timing cover? I have seen heavily pitted timing covers.
I had the head checked at the machine shop. All checks were good.
I did not get any pics. But the pistons and cylinders looked good.
Used new ARP studs and torqued to their spec. 80ft-lbs.
True until the engine is shut off
It’s a 1FZ-FE.
Ok, so you ripped it apart before properly diagnosing it?
No compression tests
No leak down tests
No cooling system pressure tests?
Now you're questioning what failed.
Did you flush the cooling system?
Did you do an oil change after running for a few minutes?
Is this all residual oil and coolant that didn't get flushed?
Don't run it with any coolant in the oil or you'll be rebuilding the bottom end next.
No leak down tests
What can I say, I like taking things apart. That was probably the easiest head gasket I have done.
I didn't pressure test the cooling system. We know it was leaking into the oil.
Cooling system flush was done.
Has had two oil changes shortly after getting it back together.
Still leaking coolant into the oil somewhere.
What did the cylinder walls look like when it was apart?
Did you look for any cylinder wall cracks?
You have coolant in the oil, but do you have oil in the coolant?
Any exhaust gases in the coolant?
Coolant into oil would be head, HG, block but may not get oil into coolant.
My case was the opposite.
I had traces of coolant in the oil. Not visible but Blackstone detected.
Nothing in the coolant.
After much analysis/troubleshooting, I replaced the entire oil cooler and problem disappeared.
This was after a complete teardown and rebuild. Frustrating because I thought I might have done something incorrectly.
Oil cooler replacement isn't too terribly expensive and not difficult to replace.
Happy trails
Happy trails
I have a spare oil cooler. I pulled the old one last night. I just need time to get the other oil cooler off the spare engine.
Cylinder walls all looked good. They all looked the same.
Ordered a block tester, should be here today.
@Fishstix said in post #1: It’s a 1FZ-FE (FZJ80)
No 80 Series left the factory with the 2F engine. FWIW
