Coolant Hose Help
Saudi Arabia
I have a 1994 FZJ80 with the 1FZ engine. I'm in Saudi Arabia and it's a carbureted version. I have a coolant leak on the driver's side of the engine block, and have isolated it to a capped "nipple". It is NOT the PHH. It is the outlet for the hose circled in red in the attached photograph. This is simply capped off on my vehicle and the cap is leaking. Can anyone tell me where this hose is routed? Does it go to somewhere else on the intake on an EFI engine? Thank you for any help you can offer!
Thank you. Do you know if it is a threaded nipple or is the nipple a part of the head? It would be great if I could get an actual metal plug, instead of a weak rubber cap.
The nipple is pressed into the head.
Discussions concerning Toyota nipple clamps should be in the shibari forum. Just saying....
My two favorite things? Toyotas and nipple clamps? JK...
Well, the original cap has lasted 220,000 km. I just need to find a replacement. Beno, do you have an actual part number? I'm looking at the diagram I have (similar to the one you posted) and there's no part reference number, just the 11101T.
