My '95 cruiser has been having cooling issues since it snapped an alternator belt last week. When the belt snapped, it took out the coolant hose that runs to the top of the radiator right above the alternator. So I replaced the alternator belts (and AC belt for good measure), put a new hose with new clamps in place of the one that got knocked off, and refilled the cooling system with coolant (Napa Extended Life) since it had sprayed a bunch all over the engine bay. But now the coolant level keeps dropping and I can't figure out why.
Yesterday I topped off the radiator and coolant reservoir and drove around for a little while. The engine temp ran high, but not into the red. When I got home, the reservoir was still full, but the radiator was sizzling through some small gaps in the top next to the battery (possibly a problem?). This morning, I go out to check the coolant level and the reservoir is completely empty, and there's no visible coolant in the radiator when removing the top cap. However, I can't see any signs of coolant leaking out of anywhere.
There's also an error code P0115 - Engine Coolant Temperature Circuit Malfunction that popped up when I drove it before realizing the coolant was disappearing and it almost overheated.
I'm now stuck on what to do next. Should I just take it to a shop, or is there anything else I can check myself first?
