- Vehicle Model
- 40 Series
Gauging by the number of new Kilometers Per Hour clusters that sell on eBay think that its safe to say that many of you are driving around with a Speedometer that reads in Kilometers Per Hour. You probably have gotten pretty good at dividing your displayed speed by 1.6 or you have a cheat sheet next to your speedometer or even better you have little labels on the glass of your speedometer. BUT now you can correct your speedometer readings and easily view your speed in Miles Per Hour exactly the way that God intended.
This kit has 2 pieces the first is a ring that covers the existing numbers with the equivalent Miles Per Hour values. Also included is a Speed MPH sticker to cover the offending Speed KPH on the Speedometer face. Once installed, it blends very well with the black speedometer face.
Some Details of the Kit.
Pics
This is the decal that will be used for installation
This is an example of the cluster in its original state
This is an example of the decal in place as its being installed
Here is the completed installation
Here is an installation video.
- The Speedometer does need to be removed from the Cluster. It is very easy to remove I have a video to explain this process.
- The needle does not need to be removed to install the kit. Although it is easier without the needle.
- The values can be changed to accommodate larger tires (This is for any FJ40 speedometer, contact me with your new values and I can change for a $10 charge)
- The color of the numbers and Speed decals can be changed (contact me with your color request and I can see what choices I have $5 charge)
- This solution is reversible. The decal can be removed later if needed.
- This DOES NOT fix the odometer racking up Kilometers instead of Miles. Might be obvious but just in case.
- Finally if this is not up your alley I will complete the work for you . Simply send me your cluster and I will install for you. Contact me for more info.
Pics
