Considering GM alternator install
Yuma, AZ
Okay, I know this has been hashed to death in many a thread. :shotts:
I am clear on how to install and wire the GM alt.
I am reasonably clear on what happens to the stock wiring - I believe it basically gets disconnected and tied back except where I will splice into it for the feed wire.
I will add my own charge wire and an idiot light and voltmeter.
What I don't get is why so many threads say that you can NOT continue to use the ammeter. The ammeter is on its own circuit from the fusable link on the + terminal of the battery (isn't it?). Shouldn't it still continue to function and show what is going on? Even if I add an idiot light and a voltmeter?
I have found many threads about installing and wiring these things - but not a single one that completely addresses what I consider to be all the necessary details.
With the stock setup the whole 30 or 40 amps travels through the amp meter, and back to the neg batt terminal. With a GM alt you might be pushing 100 or so amps, which is far too much for the stock meter to handle. There is a good posibility you'll fry the wireing if you have a heavy amp draw condition. Running a heavy gauge wire from the alt to the battery is the best route, and from the batt to the fuse block.
Most of the newer GM alts use a one wire setup, so no idiot light. You need to use the older two wire ones to get the light, which is what I have and it works fine
I hear ya
I read 10,000 posts and had to use tidbits here and there. I put a cs130 GM in my 79 and its working great. The 130 is a single wire. I just mounted it and ran the 1 wire from output to batt. Put in a volt gauge and all is good. You will need however to get a double pully to fit the GM and order a set of brackets from http://http://www.alternatorparts.com/Alternator_brackets_1.htm
You want part # A 285 for the brackets. I do not have a part # for the pully i got it from a local alternaor shop. its a double pully that has a gold color. I could probably get the part # from him if you need it. I love the new setup. Easy and i can get one of these alteranators anywhere. It puts out about 105 and I have 6 Hellas, winch, amp and strobe lights. I can run it all and have no problems.
Thanks, Big B - that's the information that I was looking for. It's not that the ammeter can't be used, but it's the higher amps that make it a bad idea.
I get it now.
Eric,
Have you seen this site?.....http://www.madelectrical.com/index.shtml
There are descriptions of the advantages of using three wires instead of one with the GM alternators - allowing the use of the stock ammeter, better regulation of the charging, letting you have an alternator warning light, and other details.
Still, I like and use a single wire setup.
honk said:
Eric,
Yes - I have spent quite some time there. I am considering their wiring kit as well - if just for the instruction booklet that it comes with.
I also have a neighbor whose family business is alternator and starter repair. I'm going to pick his brain as well.
Ugh - I should have paid closer attention to that. That bracket that you referenced looks like it would do the job. Instead, I cut the mouting ears on the alternator - thus rendering it unuseable for a core.
Oh well. I'll do it right whenever this one craps out. Thanks for the info - I may go ahead and order that now just so I have it.
ONE MORE QUESTION FOR EVERYBODY!!!
I got the alternator installed and wired last night. It's a 12SI 3-wire. The main Batt charge wire goes to the starter via #4 welding cable. The #2 wire also goes to the starter via 10ga wire. The #1 wire goes into the dash, through a light, fuse and splices into a switched hot wire feeding the fuseblock.
I disconnected the stock external regulator and the alternator pigtails.
Right now, I have the 2 wires disconnected from the back of the ammeter but my question is this:
Knowing that the ignition and constant hot side of the fuseblock is fed through this circuit coming off the fusable link on the battery - and the ammeter too. Is the ammeter an integral part of that circuit, or did it branch off? In other words, will I have to connect the two ammeter wires together to keep the ignition and fuseblock hot, or can I tape them off and leave separated?
I am not worried about the factory wire there, because the alternator will not be charging the battery through it anymore. It will only be carrying voltage from the battery and will see no heavier loads than it ever did. It looks to be 10 or 12 ga.
Edit:
I think they will have to be spliced. I would basically be doing this, as in the Mad Electrical writeup:
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
What do you think?
You will have to splice the wires off the ampmeter together, the way the meter works is it shows the flow of electricity passing through the system. If you do not splice the wires you will not have any power, however you may want to check the wiring diagram to be certain although it wont hurt to splice the wires together.
That sounds right to me. Then I just need to make sure that the old BATT wire from the original alternator harness is taped/insulated well and tied back so it will not ground out on anything.
I should be starting it up with the new alternator tonight!
Doesn't the Ign wire to the alternator need to be switch at the ignition switch?
There is no reason not to leave the amp meter wires connected. It will only read the chassis current, but not the charging current.
If this bothers you, you can also just connect the two wires to the same side of the amp meter (bypassing the meter). This is better than just leaving them dangling or just taping them together.
My opinion is that the madelectric site has a grain of truth, but it is also larded with hyperbole and unsubstantiated opinion.
Examples:
The main problem with 60s chyrsler products wasn't the fact that they used amp meters, but it was the firewall connector for the current.
Amp meters aren't "old fashioned", they are just more expensive, which is why the other manufacturers used idiot lights. Amp meters tell you useful info about your charging system that volt meters and idiot lights don't.
Voltage drop in the charging wire is not a significant problem, so you don't need remote voltage sensing. If it was a problem, all the manufactures would use a few extra feet of wire to implement "remote sensing".
the question has also been brought up (when I was doing this) that remote sensing.... on our OLD harness with decent resistance.... can result in overcharging the battery.
I left my ammeter hooked up. It shows the vehicle draw (which is no different than before) It just doesnt show anything about charging from the alt.
Hi amps from the alt are going directly to the battery, not through the alt.
Thanks for all the comments - I got it finished and it started right up tonight. It functions exactly as it should - idiot light and all. Voltage at idle was right at 14.5.
Pin Head: I decided not to use the factory harness at all (except for the hot wire from the battery through the fusable link). I got my switched ignition source at the fuseblock and ran that through a fuse and the idiot light out to the #1 connection on the alt.
The majority of voices that I heard through all of this said to bypass the ammeter - so I did. Oh well, what's done is done and it is working well. I will have a voltmeter installed next. I do understand that the ammeter and its wiring is safe (I'm still using it) but the ammeter would not show me the status of the charge - only the vehicle draw as Klunky Chirs mentioned.
I'm happy with it and might even get around to writing it all up sometime soon. There are some points to this conversion that I think a lot of existing links left out.
thanks again for all of the comments.
...now if I can just get those frozen wheel cylinders unstuck...
