Connecting Rods Length
Big difference in lenght. Don't remember exactly off the top of my head, but probably around 3 inches.
Difference in bearing size and in wrist pin size. Also type of pin (full floating in the 3FE).
Mark...
2F rod is 7.50" C to C, .990" pin bore.
Note that these are standard chevy dimensions that were not metrified.
3F rod is substantially shorter at 148,00mm. Pin diameter is reduced to 22mm.
1.6 inches difference in length. I was way off with a guess of about 3.
Mark...
The piston compression height is also significantly shorter. I think you're about right on the overall package being 3" shorter.
I thought about the piston height factor later. I'm *sure* that's what I was thinking of. Yep, that's my story and I'm sticking to it. ;)
Mark...
