confirming power seat problem
Central Coast, CA
Website
www.coastal-aquariums.com
So my pass front seat is stuck about 3/4 of the way forward. Normally not a problem, but I have been letting my 15 year old daughter drive the cruiser with her permit. So I have to sit shotgun and at 6'5" this is not too comfy.
I looked under the seat and the left long screw gear is not turning but the right is. This causes the seat to bind up at an angle. It will move forward a touch at a time but does nothing when I try to move it backwards (no sound and neither gear turns). I am thinking that this would be a motor as apposed to the white cap as it is not turning at all. Any ideas out there as to what the appropriate course of action would be here? I searched and educated myself on some of the issues, but am not sure which problem I have.
Thank in advance
Pull the seat, flip it over on a saw horse and stare at it for a minute- you can disconnect the lead screws then walk the seat into the "back" position by hand, then if you want it back forever, don't reconnect the power. But I'm almost positive your issue is the white cap & gear on one side, $25 and 1 hour's time to fix. ;)
Hmmmm......sounds like a shady attempt at selling some screws and caps, but I'll bite.:flipoff2: I think I will just get it back manually for the SnT weekend then order some parts from you. Thanks for the quick answer.
Seat moves up, but not back
On the way to work today I tried messing with the seat postion again. I moved it up a inch or so. Then tried going back, and it wouldn't. So I tried forward again to see if I blow a fuse and it went forward, but still won't go back. Now what happend? I better not eat lunch today.
i'm betting on the gears and caps, but if you need a motor, let me know. i have a driver's seat with all good motors and switches in it sitting in the garage. i can let it go cheap.
Looks like your right. Is there anything special about putting it back in?
Are the threads chewed up? Take a peek into the hole too and looks those threads and if you can see the gear inside.
If all looks well, screw it back in and keep an eye on it. If it pops out again try a dab of superglue or similar to hold it in but not much in case you ever need to back it out.
If the threads are messed up then order a replacement (or two :)) from Nakman at the site in his sig line and you'll be back in business. Try avoid futzing with the movement of the chair until you replace the srew so you don't mess up the internal gears.
:cheers:
I have the same problem with mine... both seats are missing the cap... If I put my finger were the caps goes the seat work just fine... Take my fingers out and the seat gets stuck.
I thought I was doomed before I came acorss this thread (wasnt even looking for it)
Now that I k now that the caps can be ordered and replace I will give this a try.
THANKS!
THANKS!
Yeah I just seen the cap sitting on the carpet next to the seat and I was like: whats that? Put it in the cup holder and seen the hole after jlg32281 put his bet down.
Thanks jlg32281
put the cap back in and it should work as normal. Same thing happened to mine a few months back
