Cone Washers Question
Discussion in '40- & 55-Series Tech' started by VA.CRUISER, Mar 6, 2007.
  1. VA.CRUISER
    VA.CRUISER
    437
    41
    Feb 25, 2002
    Hey guys what all can you get cone washers from to fit Aisin hubs. Does the 4 Runners use them in the ADD hubs? Or does anyone have some for sale I need enough for both hubs and don't want to have to spend $$$ on them :D
    Thanks,
    Burl
  2. John Smith
    John Smith In the garage
    4,201
    Media:
    6
    Albums:
    2
    257
    Jun 7, 2004
    Maryland
    I know minitruck manual hubs use the same cone washer. I don't see why Toyota would put a differnt conewasher to hold on the ADD but I don't know for certain. Hit the junkyard with a caliper and let us know if they are the same. Or just call Ryan, he will know as he used to have ADD on his 4Runner.
  3. bandy rooster
    bandy rooster
    1,935
    3
    Aug 11, 2005
    Sunny South
    after two unsuccesful trips to the junk yard to find them, i finally chose to buy them new from trail gear (awhile ago)
  4. rusty_tlc
    rusty_tlc Dain Bramaged Member
    13,409
    Media:
    3
    Albums:
    2
    913
    Jun 23, 2005
    Reno, NV
    I'm not sure what ADD is.
    Wanna go ride bikes?
    JK, I do know that the IFS hub is identical except for the inner ring.
    I grab all the cone washers I can find at P&P, most people leave them on the ground when the pull the knuckles/birfs out of a rig.
    Edit, the guy at the foreign auto dismanteler here in town knows to keep them, he has a bucket full in the back. You might check with a local yard in your area.
  5. JasonH
    JasonH
    2,186
    Media:
    1
    98
    Jul 12, 2002
    McKinney, Texas
  6. exmodlad
    exmodlad
    1,034
    Feb 21, 2006
    i have a set of them here...good condition
    $24.00 for a set of 12
    Best Regards
    Gord
  7. dieselcruiserhead
    dieselcruiserhead
    2,673
    9
    Jan 2, 2003
    Park City, Utah
    i have gotten them from the dealer also.. Not too bad, $$ wise.. A buck or two each washer...
  8. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,374
    Media:
    17
    Albums:
    1
    726
    Oct 1, 2003
    MN
    They are the same.
    Automatic Driveline Disconnect, iirc.
    :beer:
  9. cruiserlad
    cruiserlad
    72
    1
    Oct 14, 2004
    Meridian, ID
    My dealer gets $5.00 each for them. I've tried all the PNPs in the area and most are clueless about what they are. I've spent as little as .50 ea. and that was at a local parts store. I guess you can get them some where besides Toyota. HTH
  10. Poser
    20,374
    Media:
    17
    Albums:
    1
    726
    Oct 1, 2003
    MN
    Should post up the name of the store and the generic part number that you found for this application.....
  11. VA.CRUISER
    VA.CRUISER
    437
    41
    Feb 25, 2002
    Thanks guys I know where a couple of 4runners are so I'll check them out ;)
  12. CruisinGA
    CruisinGA
    6,168
    16
    Mar 27, 2003
    Georgia Tech
    80 series work too...
  13. ranger
    ranger
    1,160
    6
    Jan 18, 2003
    Mountain Hole, Idaho
    Marlin sells them to if you are in a pinch.
    For a small piece of steel, they sure aren't cheap.
