I've been having and issue with my LC having a rumble/rough running issue when first started. I had a compression test done and it came back as follows:
#1-90psi
#2-170psi
#3-155psi
#4-90psi
#5-165psi
#6-160psi
They also ran the test "wet" on the weak cylinders with no improvement. With no improvement shown when "wet", they told me there isn't an issue with the rings/pistons, rather in the head. That was all the info they had. Any suggestions as to what may be the cause. The HG was done 22k ago. Maybe going out again? Any info is much appreciated. Thanks!
#1-90psi
#2-170psi
#3-155psi
#4-90psi
#5-165psi
#6-160psi
