I have had some of the typical symptoms of leaky valve stem seals with the puff of smoke after idle etc. My oil consumption has increased substantially here lately and some of it is being pushed up out the air intake and valve cover hose. Oil and antifreeze clean. I plan to redo the head.valves soon.
I wanted to make sure all was well with the rest of the engine so I did a compression test today. I pulled 185 lbs to just over 190 lbs on all six cylinders.
However, I was by myself and didn't get to watch the gauge to see how much it went up with each stroke. I did read an article about removing all plugs and holding the accelerator to the floor and doing the same number of strokes for each cylinder. This was after I ran the test today. I didn't hold the accelerator to the floor.
Anyone on here have a good guide or write up to performing a proper compression test? I may just have to position the gauge where I can see it while cranking it over.
This is the article I read after I had already performed the test today. What I read prior was not as detailed. Technical Articles at Greg's Engine & Machine
Thanks.
Thanks.
