Learning slowly. '76 2F
Don't have the FSM so I didn't read it.
Did a compression test cold, and the numbers downright scared me.
Let it warm up, not fully up to temp, but not cold. Also did not open the throttle.
Got the following #'s
1) 90
2) 70 then 90 (did it again! )
3) 90
4) 90
5) 90
6) 90
These were all done dry, again, with the carb closed
My question is, how much difference does the carb make? These numbers seem very low to me, but everything seems to be running fine? Have read through other posts, searched, but did not find anyone with numbers this low. How many more PSI should I see with the carb open? Did not try a wet test.
Also saw many posts that advised people to adjust the valves then do another test, without the FSM, is there anywhere online where this procedure is outlined - and how hard/lengthy is it? It is damn cold outside.
I only did this out of curiosity, with my carb icing up at the beginning of the week prompting me to maybe check a few other things! (coolant is good to -45, I'M NOT GOOD THAT FAWKIN COLD!!!)
Please advise...
1) 90
3) 90
4) 90
5) 90
6) 90
Please advise...
