Compression results
Little Rock, Arkansas
Well the results are in. I tested the compression while the engine was cold. It is a 72 F engine with 69000 on the odo.
First group of results are turning over engine 3 times
#1 135
#2 140
#3 140
#4 125
#5 130
#6 140
Second group of numbers is turning over engine once
#1 120
#2 125
#3 130
#4 115
#5 120
#6 130
Well any input on these #'s would be helpful, this is my first compression test..next week axle rebuild and swap!
Thanks,
Jake
These are good numbers. Number 4 and 5 are a bit low, indicating possibly that you
are burning the #4 and #5 exhaust valves, which is a common problem if you have
a leaky brake booster.
If you are interested in engine health, the next thing to check is oil pressure, using
a mechanical gage, at idle and at 2000 rpm, hot and cold. If the oil pressure is
good and your compression numbers are as above, then you've got a lot of years
left on your F.
What's the general rule, compression should be within 20% on the high and low cylinders? So your being 140, 112 would be the lowest that it's "ok". I could be wrong though, it's been a little while for me.
A mechanical oil pressure gage will be about $25 and should come with the adapters
to screw the gage into the block where the existing oil pressure sender is. The 2000
rpms is nothing special, you just want to test oil pressure at idle and at "road speed",
hot + cold. The hard part is getting your electrical sender out without damaging it,
then plumbing the plastic oil line to your block and then to the gage. Some people
run a dash-mounted mechanical gage for insurance, mine I just hook up when I feel
the need to diagnose.
I think those numbers are satisfactory. As rgentry says, if it's on a 72, with the notorious booster burner, I'd spend a minute or two checking into that as well. Try a thread search on this before you ask.
