Compression question
Pa.
What's the reason for holding the carb open while doing a compression test?
How will it change the compression number? Will it show a higher or lower number with the carb closed?Just a dumb question I was thinking about and don't know the answer!
It'll just read false, high, low, wrong. The reason is that the pressure will build some against the throttle plate partly but it's mostly because a closed throttle will restrict the amount of air that can be drawn into the cylinders to be compressed. Measurable pressure won't build in a vacuum.
where's pin head come from? :)
Pin_Head said:
I come from S. Sacramento, but I moved to the OC because they have jobs outside of state government. The weather is a little nicer too.
I think he means that he wants to know where the name "Pin Head" came from.
Take a guy who always gives correct (from experience and formal training + natural smarts) information who has a name like PinHead and it is a bit of an irony.
I remember when you had the PinHead for an avatar.;)
Ed
You have saved me more than once or twice, or thrice.
Zippy.....:D
"Pin Head" is what my service manager called me in the first shop I worked in when I was working my way through college. It was usually preceeded by "fawking" as in "Where is that fawking pin head college guy". I was the only guy in the whole shop that wasn't an ex-con. It was the only job they could get where they could keep on stealing and not go back to prison. I only worked there for 2 years before moving to VW, but I learned a lot.
