completely non functional dash and other electrics
I just purchased a 1990 hdj81. It had been sitting in a Japanese port awaiting shipment for 8 months. In so doing, the batteries went dead.
While boosting it the ECU was fried. Supposedly it was replaced. unable to confirm.
When it arrived, It would not start. I changed out the 10 am "Guage" fuse as per another members advice. It did allow the truck to start fine.
However, None of the dash functions are now working nor are the electric windows , door locks, sunroof etc. the Head lights are fine, running lights are fine, signal do not work, break lights do not work.
The 10 amp "guage" fuse is now burnt once again.
Is it possible for a fried or malfunctioning ECU to be causing this?
If so, where is it located? and how best to trouble shoot it?
Or what other causes might you guys suggest.
Also one more fuse is burnt relating to an ECU.
Regards,
Robin
What ECU?
Since the truck been sitting so long. I would start it turn on the climate control on auto and let it run for a while to dry everything out.
Have a couple of 10 Amp fuses ready just in case they blow again.
Check under the dash board to make sure the previous owner did not have a bunch of of electrical things incorrectly connected or shorted out.
My first 92 truck would blow the 10 Amp gauge fuse once or twice a year.. could never figure out the cause. Kept a bunch of 10 AMP spares in the ashtray.
Cheers, :beer:
Landcrusher80
This is what I am trying to figure out. I was told that one was replaced. Maybe I am thinking of an ECM?
The computer module is what I am assuming they meant , when they said they replaced the ECU
yes, the starter is 24 volt.
I have further fine tuned the problem to be specifically related to the in dash fuse box, top fuse on left. indictated as the ECU 2 fuse.
It keeps blowing the fuse every time the battery is connected.
or if the battery is already connected. Then when a replacement fuse is placed in, it emediatly burns out.
this is why my original question of. where is the ECu located?
