Well, the first of many baseline procedures are complete. I followed all the guidelines included in the FAQ's and did a little "overkill flushing". The coolant in my 80 looked to have been a half-arsed attempt to swap to Toyota red. The liquid was a redish brown nastyness, and did foam up pretty good as I did the flush. I'm not sure if the PO had tried using a flush chemical and didn't get it al out, or what. The block drain bolt was easy enough with about 3 feet of extension for the ratchet, and I now have a flush "tee" in line with the heater hose. The thermostat and PHH were also done while I had the system empty, and now I have a little btter peace of mind than I had before. All together, it was about a 4 hour procedure and about a
to a
job, but not bad at all. Thanks again to the MUD for some great knowledge and help.
's
Now, where is the best place to pick up a Scangauge II?
Matt
to a
'sNow, where is the best place to pick up a Scangauge II?
Matt
