Completed! Offroad utility trailer build
Thanks! Good luck with your build!
Thanks man!
Just got most of my main welding finished on my Harbor Freight 40x48 trailer conversion.
Welded the entire frame together.
I used the original tongue as the rear bumper/extension piece to make it 6' long. That has the VIN/serial # on it as well.
Used old bed frame angled rails to tie it all together and strengthen the crossmembers.
Added a 3500lb axle and shocks along with an 11' 2x2 1/4" tongue from front to back with rear hitch receiver for a 4 bike rack.
33" tires on black steelies.
Used a neighbors old workout rack tubing to make the rear shock mount crossmember and the tongue supports.
Next up is a box on top with doors, slide out cooler, solar/battery setup and weld a rack all around it.
Took a few of your ideas and just doing this on the cheap. No where near your quality of work but it's gonna work out nice. i may start my own build thread for other Harbor Freight owners.
Here's some pics.
Is a VIN that difficult in your location? In KA I can create my own for a trailer and the DMV is fine with it. They just won't tell you directly that you can do it.
I spy a certain steeker that says "FYYFF". :)
Well as far as I know, in Ohio you need a Title to register it but I think you can also have a bill of sale and a certificate of weight. Not sure if they give it a VIN with that. All I know is mine came with a Title and VIN (I believe it’s a VIN) when I bought it.
And yes, are you on ADV??
This build was skill, talent and art! Simply amazing!
This is exactly the suspension set up I was looking for to model my build off of.
Thanks!
Suspension is 5 years old and going strong. I looked into using axle-less suspension for better performance over certain types of terrain, but in the end I preferred using off-the-shelf suspension parts that I can quickly and easily source for repair/replacement. It was also less than half the price of the axle-less. No complaints.
