Complete table of 200 series traction control options
Well, aren't you the lucky dog🐩???
I have for your viewing and motoring pleasure:steer: a table of all the various settings. A whopping total of 10 options! It will be up to you to decide how and when to use these options - the debates can get, shall we say "interesting.":bang::slap:
As Sargent Joe Friday (Dragnet) might have said, "just the facts ma'am" Be nice with comments, it is the holiday season, after all.🎅
4 High Options
Button(s) depressedNotes
Default Mode no Selections made when starting in 4 High, (TRAC ON by default), TORSEN activeTORSEN center differential in use, plus traction control (TRAC)
Center Differential locked (Differential Lock button depressed), (TRAC ON by default)TORSEN center differential behaves like a traditional transfer case, Like old school 4 High with traction control (TRAC)
Center Differential locked (Differential Lock button depressed), TRAC OFF (TRAC button is depressed)TORSEN center differential behaves like a traditional transfer case, Like old school 4 High without traction control
TRAC OFF (TRAC button is depressed), TORSEN activeTORSEN center differential in use, but no traction control, theoretically like old school 4 High, but with differing proportions of power to the F/R axles
4 Low Options
Multi-Terrain Select, TORSEN active (default when switching to 4 Low)Aggressive traction control (w/various terrain settings) TORSEN center differential in use
Multi-Terrain Select, Center Differential locked (Differential Lock button depressed)Aggressive traction control (w/various terrain settings) TORSEN not in use and behaves like a traditional transfer case.
Crawl Control, TORSEN active (i.e., not locked)Aggressive traction control (w/various speed settings) TORSEN Center differential in use. Speed is controlled by crawl control setting and not by manual foot control. Note: This is the only mode where turn assist can be used.
Crawl Control, Center Differential Locked (Differential Lock button depressed)Aggressive traction control (w/various speed settings) TORSEN not in use and behaves like a traditional transfer case. Speed is controlled by crawl control setting and not by manual foot control
TRAC OFF (TRAC button is depressed), Center Differential locked (Differential Lock button depressed)Old school 4 Low, TORSEN not in use and behaves like a traditional transfer case. No F/R axle traction control enhancements
TRAC OFF (TRAC button is depressed), TORSEN activeTORSEN center differential in use, but no traction control, theoretically like old school 4 low, but with the potential of differing proportions of power to the F/R axles. No F/R axle traction control enhancements
Thanks! I just copied and pasted it, and made a copy for the glovebox..........
