Complete and Utter Newbie
Southern California
Howdy everyone,
I am a new to me 80 series owner, and complete and utter newbie at cruisers and car maintenance in general. I apologize in advance for my total beginner-ness but I am trying to learn and this forum is a key part of that process. So my cruiser:
1996 cruiser, white, stock, locked, fourth possibly fifth owner, 185K miles, cosmetically good condition externally, inside ok, some internal rust in rear quarter (base of jack, cargo floor fold down hooks). CA original vehicle been in Oregon last ten years, bought from dealer in Portland and shipped back to Cali. Bought fairly cheap and been the shop last three weeks.
Now again, I'll be honest, never changed my own oil, changed many tires but that is about the extent of my wrenching experience (which don't count for squat). I am eager to learn how to do stuff myself, and understand mechanically how stuff works just never taken it all apart and put back together.
So since the cruiser arrived I took to a local mechanic and they did the following:
  1. Oil change
  2. Block/HG test - passed
  3. New front and rear rotors, pads and calipers, new brake fluid
  4. new tires, old ones were 2/32", got BFG ATII 33's
  5. replaced thermostat, heater valve (at back against firewall), all radiator hoses including PHH
  6. new battery
  7. new plugs
  8. drained and refilled front and rear diff
  9. due to leak in transfer case replaced speed sensor and Oring and fluid
  10. tranny fluid change and new filter
  11. replaced both oil pans due to leak in upper pan, and the pick up pipe was crushed so replaced too
  12. replaced power steering fluid
  13. replaced radiator shroud and fan clutch with modded Blue hub
  14. new K&N air filter
That all wasn't cheap but I have been saving my pennies as I've been wanting to upgrade to a cruiser for a long time. But I still have a million questions, and don't completely trust some of what the shop has told me.For instance, post brakes overhaul that I did, the pedal is still fairly soft, they are now telling me that I probably need to replace the master cylinder, which will stiffen up the pedal feel and brake function if I do it. I don't know if that is true or not. Anyway,
Her ongoing issues:
  1. soft, high pitched brrrrr noise from around the shifter at ~1500 and 1800 RPM occasionally when accelerating, intermittent in occurrence
  2. oil pressure gauge on the dash doesn't work
  3. lockers won't engage so far
  4. the power and 2nd buttons don't do anything, well the lights on the dash don't light up at least so maybe they work and the bulbs are dead
  5. Right rear passenger window is dead, just found that one yesterday
  6. I fear the sunroof and rear sliding windows leak like sieves
  7. would like to lift her and slider install but have to save up
Anyway, she's my new daily driver and I love having her and am eager to learn. I apologize in advance for dumb questions but I gotta start somewhere! Thanks
Uluabob
1 k and n filter sorry but toss it unless you can oil it right , it will foul your maf sensor causing codes and oem filter is better and washable
2 is the oil sensor plugged in, looks like a bell on pass side has two wires , if so and no work replace from Toyota around 50 bucks and 5 min of your time
3 don’t change filter on your tranny
do drain and refills no flush, you have a screen
4 sunroof and sliders probably clogged drain run weed eater string down drains and check drains are not plugged at bottom below door
5 pwr button gives you a higher shift point 2nd gear start starts you in second instead of first
6 go drive in 4 low with cdl on, turns on and light up dash when shifted to 4 low, to engage lockers just keep turning figure 8s till they engage, with f the cdl does not lock then the lockers won’t either
:flipoff2: welcome to mud, empty your wallet on the way in, sit down, get comfy . . . .
Now, search! :lol:
There's loads of info (and help) on all your questions, all well travelled roads.
First thing, find a mechanic with a reputation for working with landcruiser.
They are mostly easy to work on, and well built, but they do have their own peculiarities, some that will catch your average mechanic napping.
The soft brake pedal sounds like they haven't done a complete bleed of the brakes. The rear brakes can be frustratingly tedious to bleed, partly due to the LSPV.
Do the figure eights off pavement. In dirt, mud (IH8MUD), or gravel.
Now, search! :lol:
Cheers for the advice, now to go look up LSPV !
Welcome!!! :flipoff2::flipoff2::flipoff2:
The soft brake pedal could mean that it needs better bleeding. Some of these are a bit temperamental when bleeding. Must activate the ABS, then bleed again.
They have to make sure they bleed them in order and include the LSPV in the order.
LSPV
RR
LR
RF
LF
LSPV
High pitched noise COULD be the start of U-Joints.
Go buy a grease gun from Harbor freight for $12-$15. Buy a tube of Lucas Red-N-Tacky from Walmart or O'Reilly and install that in the GG.
Park your truck on a FLAT, LEVEL surface, CHOCK the wheels front and rear of one axle. Place the truck in neutral, engine OFF, do NOT set parking brake. This will make your drive line UNLOADED.
Slide under the truck, find the grease zerks on each end of the drive shaft and put 3-5 pumps in each zerk. (wipe off the tip of the zerk BEFORE you put the gun on it) There are (3) per driveshaft x (2) driveshafts.
Also, before you grease it, wiggle each end of the DS up/down, Left/Right. This will feel for play. I am NOT talking about rotational play because yes, there will be some. (about 1/8 turn max) If you have play up/down or L/R, you MAY have bad U-Joints. Grease them anyway (again, only 3-5 pumps) and see if the noise goes away or gets quieter. If so, you will soon need new ones.
Good Luck!
Let us know what you need and we'll help walk you through it!
LSPV
RR
LR
RF
LF
LSPV
Good Luck!
Awesome, OK, will investigate and try it out, I'll search to see if there's a map or figure showing the zerk locations, and I'll check the amount of play, fortunately there is a drive shaft specialty shop in town if need, and I'll search for brake bleeding instructions, thanks!!
My advice just sell me the cruiser for cheap, especially after you put all that money in it. Lol. You are on the right track and doing everything needed to get it back to good running condition .The fact that you are eager to learn means that you will figure it out .this is a great forum but always search before posting or you might be given a hard time just for fun. Welcome to the club. If you are not hooked on cruisers yet you will be soon.
Sorry, I just need to vent.
K&N air filters = NO. I have years of experience with an OEM testing engine dirt / dust / particulate ingestion (warranty forensics). The K&N air filters (and the like) are absolutely horrible at keeping dirty air clean. Any deep pleat paper style air filter (even FRAM) are unbelievably much better at cleaning the air. (like 99.9% efficiency VS. 80% cleaning efficiency). Even a properly oiled, NEW K&N fresh off the shelf is horrible. Return that sukka and drive happy!
If you are looking at a used car and see a K&N sticker - RUN!
Land Cruisers ROCK!
Land Cruisers ROCK!
Good to know. Thanks.
