compatible strut mount Bilstein 6112/2010 Tundra
Colorado
Help! Keeping it short but my toytec alumaboss 2.0 cratered while out of state on an elk hunt so I got towed to nearest town and in a pinch had Bilstein 6112 front suspension installed. the Shop blew the install, leaving out a metal bushing/spacer on one side that was to prevent strut from excess vertical travel thru fender well and left off a rubber bushing on other side. Seriously. Took truck to my local terrific offroad shop just to verify install an d check if torque was correct and holy cow did they find a mess. they were surprised the 6112 install had not come apart given parts that were missing.
My ask: I need a new strut mount kit that will work with 6112s on my 2010 Tundra . Kit needs to include rubber and metal bushings retainer rings etc.
Will the KYB SM5737 kit work specifically with the Bil 6112 I now have and if not what am I looking for?
Also see Masterpro FM2000 also lists as working for 2010 Tundras. What I do not know that some of you do know is if the fact of having bilstein 6112 in front in any way changes what strut mounts can work. I.e. if a strut mount kit such as the above two options say they fit like OEM ( they do say that on autozone and oreilly sites) ) does that also mean they work with the 6112 set up?
I guess what i need help with is will either of these options work with my now non OEM front Bil 6112 suspension? And if so, which I should use and why? And if not, same question.
Thanks experts!! I am flying blind and need solid guidance.
Got my needed answer from a different Tundra focused forum. Answer is yes Sm5737 should;df work fine with my 6112s.
Thought for sure this forum was the place I would get the help from first.
