Column Shifting problem fj40
I have a floorshift kit as well. Could box up with your sbx. Not that I'm suggesting you go that route.
Jim, I had a HECK of a time locating your store on Ebay last night. You ought to have a link to it in your sig line.
Information when you have time.
Thanks
Thanks
I checked Section 081 of my website. It looks like a basic kit (used cover and lever) start at $95
I converted to floor shift because the column shifter linkage was so badly worn that I gave up on what always turned out to be temporary repairs. No shifter parts anywhere.
The shifting would jam and lock between gears - too often out in the middle of a four lane intersection between 1st and 2nd and me wanting to turn left.
OP, as long as you've got the column shifter look to linkage problems before thinking about forks or synchros and such internal trans parts.
The 3 speed trans is a rock. Near bulletproof, shifts smooth and easy, and all you need do is remember that 1st isn't synchro. Any later model OEM floor shift year up to 1974(?) supplies parts for converting - top cover and shifter, hole in tunnel and motor on.
In response to the above, my lady is a 1970 from south of the border. It is a three speed floor shift. there is a gap between the steering wheel and the column. I'm wondering if it was formerly a three on the tree and converted to floor shift. Thoughts?
