Column shifters Help Required
Orlando, Fl
while driving today, my gear shifter, the long rod that runs down the side of my steering column decided to disconnect from the top part of the column. so, how do i fix this? i will have pics soon.
For one thing, it should be at the top, not on the side!
Now that we can relate "thingamabobs" to part numbers, what exactly happened? Part G in the diagram is threaded at the top end and screws into the upper plate of the steering column. Did this part break? I don't think it's possible (under any kind of normal circumstances) for it to come unscrewed since the end of the shift lever sits in the hole at the bottom end of it.
More details please.
[edit] too slow with the typing :doh:
So...I guess you are "shiftless"???
My column shift was always sloppy, so I changed to a floorshift. Goes faster now.
GL
Ed
Push/pull the little pivot pin that goes through B, H, and J. This will allow you to pull lever B completely out of J. Spring I should be under much pressure, but watch out for flying parts. Then you should be able to push G back into J, compressing spring I. Then put it back into the hole it's supposed to live in and begin threading it in. A screwdriver inserted in place of lever B and into the hole in G should help with the threading duties.
Since yours came out like this, I suspect the threads are buggered on one or both parts. The best solution is to go to a floor shifter, but in the mean time, I'd load that bad boy up with some loctite.
Reinsert H and B, then push the pivot pin back in and you should be good to go.
Eric
i believe the bolt got stripped..... only god knows how, can i replace the bolt? or is a whole end thing
It is a separate piece. $15 at Specter. Mark's off Road should have it. And a lot of folks around here who suck at shifting, LIKE ED LONG, probably have one sitting in their garage.
Guess you missed the part about it GOING FASTER, and i get a lot more "action" with a floorshift. Chicks dig floorshifts.
Ed
Ed
Soon as I repair the sawsall damage from Ed's column shifter, which he sent me, I'll have a spare floor shifter for those of you who need one for your "chicks" (read daughters). :D
haha, my chick likes to be able to sit next to me with out a shifter in the way, so thats out of the question. but its not part G, its the nut that it screws into... how can i get that out?
As I recall, it is a brass nut pressed into the turn switch bracket. I've looked at it and wondered if it would come out, but I have never tried. I suspect it means replacing the switch housing/bracket, maybe rebuild someone's who has broken the switch itself.
I might have one, if'n I didn't send it to Dave. Lemme look.
Ed
Man, I go sooooo fast with dat flo' shifter.
I think you did send it to me, Ed. I like it because it is chrome handled, rather than the black "new" ones.
Ahhhhhh...Chrome....Another chick magnet. If you don't need it Dave, send it to Jonathan. You're more of an "Elk Magnet" kinda guy, judging by your "hood ornament".
Ed
What I've got is this: not sure what was urse and what was, well, from somewhere else anymore.
If you want it you are welcome to it, Jonathan! Lemme know! :)
sand rider said:
well, how do i get the old nut out of there?
Not sure you can. You may have to replace the whole piece. The other option might be to drill it out and helicoil it.
i believe thats what im gonna need, but my turn signal switch is different, but ill dismantle that sat and take pics to be sure
The handle is broken on this one. You just would change it out for your handle.
