Hello Everyone,
I have a 92 LC 80 series with the 3FE engine and 70,000 miles
on it. It runs great except when it is first started . It has a cold engine misfire and gradually disappears when it attains norma engine temp(needle at half of coolant temperature gauge)
It doesn't have a hard to start problem --it just misfires right after it is started cold. No OBDI codes are present, CEL is off(and functional). Ambient temps in mhy area is 80-95 deg F.
What would be the best way to track the problem? cold start injector? burn valves? etc.
Thanks in advance!
Thanks in advance!
I have the same starting problem.....and hope you don't have the same end result (head gasket shot)!
