Coil Spacer Install.....HELP!
Hendersonville, TN
Hey guys, I got a pair of 1 inch spacers for the front of my LX, and am new at this. I see two bolts at the top of the coil mount, do I need to take those bolts out? I am assuming the spacers go on top, seeing has how the bottom is not a flat surface. I have 2.5 OME springs, and just want to get the front level. I have spring compressors also, if I need to go that route. Just need some advice on how to get these things mounted.:confused:
They are rings, the instructions say inbetween the springs or at the top or bottom. I placed them inbetween, but it did not lift the front at all, so I want the put them at the top, just don't know how to get at the top of the spring.
I'm assuming you are installing the rubber spacers, for those you may not have to remove the bolts. I installed the Metal Tech 1.5 inch and this is the way I did it. You don't really need the spring compressors however since you have them go and compress the spring. As long as you loosen the shock absorber from the bottom base, lift the truck from the frame (go high) while holding the axle with a small jack, then lower the axle jack slowly, the spring come off. Word of advise; watch the front brake lines, you probably have to loosen the brake line holding brackets. The rubber spacers go between the spring and the top part where the bolts are. On the Metal-Tech spacers, the spacer go between the the spring tower and the metal part where the bolts are.:cheers:
The ring type goes on top of the spring, like this: IH8MUD.com - View Single Post - Custom spring spacers by TRU I remove the lower shock mount nut, the sway bar bolt and the two nuts on the stop cone, then push down on the axle and remove the spring and stop cone as an assembly, install the spacer and reassemble. Takes a bit of pressure on the axle, but have installed J springs with 1.5" spacers this way without issue. Have never used a spring compressor on '80 springs.:hillbilly:
Did u got the spacers installed?:hhmm:
Have not installed them yet, Will this weekend thought, now that I have a pretty good idea of what to do, will take some pics.
Looks like it's been covered already but this might help:
- undo the sway bar ends bolts (where it connects to the axle housing). Do this on both sides. Some don't do this but the purpose of a sway bar is to prevent axle drop!
- use a floor jack to lift one side of the front axle off the ground. Now, keep raising until the vehicle is high.
- place a TALL jack stand (fully extended) under the frame somewhere. Find a place where the frame is straight, not curved.
-Remove the wheel on that side.
-lower the floor jack SLOWLY until the jack stand makes contact with the frame. Keep an eye on the jack stand. Make sure that it doesn't lean.
-When the spring is fairly open, remove the bottom shock nut. Otherwise, the shock will limit your down travel (droop).
-Keep lowering the floor jack and the spring should open up enough for you to do your thing. As mentioned previously, keep an eye on the flexible brake hose. Don't want to overstretch that hose!
- If the axle isn't dropping far enough, force it down by standing on the wheel hub. Another trick is to place the floor jack on the opposite side of the axle and raise it up.
Rinse and repeat for the other side.
I've heard that the rubber spacers have a short life span, FYI.
Be safe.
Be safe.
Don't mean to raise a dead thread, but what about the polyurethane spacers?
