Coil Question
Richmond, VA
I have a restored 77 FJ-40. i have an accel super coil in it. This is the third time that my coil has failed and i am tired of dealing with this. The first time it went the coil exploded, and i replaced with the same, the second coil lasted longer but then went out (did not explode). so i replaced the coil and put a resistor to put the incoming volts to 6. this coil lasted for about a year and just went out.
Do i have another problem i need to look for?
Are these just crappy coils?
It sounds like the spark voltage is too high, leading to insulation breakdown and failure. Make sure that the plug gaps are set correctly and that you have the proper Toyota plug wires.
X2 on the ND coil. If you get one for a 77, it will need an external ballast resistor to run properly. Early and late coils didn't use one because the resistance is built in to the coil.
sorry if this sounds dumb, but can you elaborate on how the plug gaps would lead to the coil failing
Not dumb at all.
The plug gap is a major factor in determining how much the coil voltage has to rise in order to make a spark. The wider the gap, the higher the voltage needed and if the voltage is high enough, it will just arc across the windings in the coil.
my mechanic said that the gaps would not affect the coil. (time for a new mechanic)
i was under the impression that a coil put out a # of volts, the voltage does not change. if the voltage does not change then wouldn't there just be no spark if the gap was to much? i understand how if the voltage was to high that it could arc in the windings of the coil.
i'm trying to not just fix it, but understand it also
A coil does have a maximum voltage, but this voltage is a lot higher than needed to make a spark. Besides the spark gap, the air/fuel charge density determines the voltage required to spark. More air = higher voltage.
This is why you need to have a high voltage ignition if you have a high performance, high compression, turbocharged engine.
The coil should be engineered to handle the maximum voltage, but in practice there is a limit to the insulation that can be used. Running it at a higher voltage than necessary doesn't accomplish anything except compromising reliability, as you have found out the hard way.
Putting a high performance ignition on a low performance engine is just a waste of money.
