Cogential A/C problem?
Wayne
Bought by His blood, kept by His power
Middleburg, Florida
I live in humid northeast Florida and the summer heat and humidity is something else. My Cruiser's A/C takes a long time to get cool but never gets cold coming out of the vents. Of course, it is cooler at night and when the ambient temp is <85 degrees. My question is this, does the FZJ80 inherently have a weak A/C? According to maintenance records, the PO had the A/C serviced and worked on a couple of times (2001-2003) due to insufficent cooling. I primarily want to know, "is this a common issue with the LC"? It has been like this since I bought it in 2003.
Thanks in advance for your comments.
Wayne
I live in Arizona and I consistantly see vent temps of <40 degrees, so I'd say that the system is capable of cooling the cabin, except maybe the 3rd row. There are lots of threads about the heater valves not shutting off, so that may be an area worth exploring.
No, A/C should be ICE cold around 40*
Make sure your condenser in the front grill is clean of debris and bugs.
You may also have a slow leak in the system or it may have been overcharged.
A set of gauges needs to be hooked up to see if the proper amount of refrigerant is in the system.
Good luck and post the gauge results for more feed back...
As stated above, you should almost be able to hang meet off the vents. I have seen 36* on my center vents a few times before ('91, should be almost the same as yours other than refrigerant used). Sounds like yours is in the same boat as mine. Bottom line, you may need more freon.
An item to check is the water valve for the heater. It should be on the firewall section under the hood. Some rigs had had their loosen up. When their dial was on COLD, it was still letting warm water through. This was the case when I first bought mine. However I am not certain if the '96 has this same water control valve.
Find a friend with some gauges and see where your at.
I live in So. Cal. & my AC will chill my hands numb.
No offense, but some of these folks aren'tdealing with what were dealing with (100% humidity--and seemingly climbing!) I have ALL NEW components in my A/C system--and it still "sucked" some of the time.
YRMV.
Jwp
LittleRock80, what is the JDM Aux Fan you mentioned, how does it help the A/C, and where can I buy one?
Thanks for your reply.
Wayne
In high temp areas all A/C functions are critical, so check everything. A common problem is the fan clutches, they are wimpy, especially the newer replacements, simply refilling with higher viscosity fluid makes a big difference. Pushers can help, but having good airflow across the entire cooler is better, so I always improve the clutch first.
I am in Houston and can relate to your humidity issues. Most times my A/C does get too cold and does numb my hands/give me chills. Also sometimes it doesn't feel cold enough and definitely takes awhile to cool the truck down once started.
Most recently it was MUGGY, I had my A/C on like always and it wasn't cool enough so I turned on recirculation and after awhile it stopped blowing cold all together. Turned off recirc and a minute or two later it was blowing ice cold again.... I am thinking the system "iced" up but could have been something electrical in a relay as well as the compressor clutch not kicking on. (From reading the pressures at a prior time my A/C compressor is on it's way out...)
Hook up some gauges, read some pressures and that will tell you whether or not your compressor is good and if your low/high on refrigerant. Also in past threads the expansion valve has been a culprit and the AC evap core in the dash has been clogged.
Wayne
Wayne,
The JDM (Japanese Domestic Market) Fan came on 80-series land cruisers in other markets such as OZ, Middle East, etc. I belive it came on rigs that had rear air (not an option in North America). It is a bolt-in and can be wired to a manual switch on the dash or configured into the cooling system to come on automatically when engine temps reach a certain level. It's @ $280 these days and you can get it from CruiserDan on this site. Dan is the parts god at American Toyota and a Land Cruiser owner's best friend. ;)
As was previously mentioned, the Blue Fan Clutch is a good mod to perform as well when dealing with this issue.
Hope this helps,
Justin
I don't have a JDM fan, but I did install a pusher fan and it helped and it was way cheaper than a JDM. Mine cost me about $50 for the fan and relays and oem pressure switch.
You might want to check the recirculation servo motor. Mine was not working so I was constantly trying to cool 100* humid air. After I realized it wasn't working, I disconnected it and jammed the flap closed so that I am permanently on recirc. This helped tons. I also left the bottom cover off of the bottom of the blower fan and it blows a bit harder now.
Good luck and keep us posted.
I live in South Florida, same heat and humidity problems, over 250,000 miles young, and my AC freezes me out of the cabin at times. All I have even done to the AC in the 1 yr/30,000 miles I have had her are to replace the AC belt and simply had them recharge the system before a long trip to Maine. Still has the original fan clutch, and the heater bypass is good. Other posts I have seen point to this bypass usually.
Mine blows 33.5 degrees when it cycles off, and I did convert it to R134a. This is in 95-100 degree weather we get down here in the summer. A/C is what I do for a living though.
The other day I laughed almost uncontrollably. I have it loaned out and the temp slider was positioned to warmer and the a/c on. I guess it's too cold.
Just as a tip, don't turn the fan on full blast, the air spends less time cooling in the evaporator box. Turn it on high later if you want, I never do.
