Code 71
Opelika, AL
If I understand correctly a Code 71 points to the EGR valve which is the code I got tonight with the paperclip method. Is this all this code points to or are there other things probably wrong too. 94 Fzj80 205K I have start up RPM's that jump up to 2000 and quickly fall to about 1700-1800. Then slowly fall down to around 1000 before I drive off. While it's falling it feels like the motor is not running quiet right. (a slight shuddering) After driving and come to a stop the engine shudders fairly bad sometimes around 400 RPMs and then sometimes feels normal at 600 RPMs. Does this sound like I have other problems? What do I need to do to get this thing running right? All help is greatly appreciated.
Code 71, or P0401 for the OBDII trucks, is the error code for insufficient EGR flow
Common EGR system problems usually relate to one of four components:
- EGR Vacuum modulator
- EGR valve
- VSV
- EGR temp sensor
Vacuum lines can cause a problem if not holding a good seal or blocked. If the port running from the EGR valve to the intake plenum is not clear, it will throw the code. That was my problem; it was totally blocked. There are some theories that bad O2 sensors can throw the code.
Here are a couple of threads on this:
https://forum.ih8mud.com/80-series-tech/65702-code-p0401.html
https://forum.ih8mud.com/80-series-tech/167042-i-hate-beat-p401-dead-horse-but.html
Maybe I should just replace the 4 parts you suggested and clean the TB and intake. I have so many miles on my truck it couldn't hurt. If that doesn't work then I can deal with the O2's. Atleast I'll end up with new parts. Bad O2's won't cause the new parts I'm getting to fail prematurely will it?
After calling local Toyota Dealer that gives Landcruiser discounts like Dan(without the supreme knowledge he has but good if you know what you need) I found these parts to be quiet expensive. I was thinking about $200, I was wrong. It was more like $400. So I might need to do some trouble shooting but still need to know if bad O2's can damage the new parts. Any pointers on what to do for a novice like myself? I did read where the one guy was saying different ways to see if vacuum would move the EGR valve and some other stuff(granted I need to read again since I didn't pay enough attention after I thought I would just replace everything).
Bad O2's wouldn't hurt the new parts. But if they are bad you should be getting another code.
The idle speed issue you describe sounds like a dirty throttle body to me. Not sure about the shudder.
aaron
Maybe shudder is too strong of a word. It doesn't feel like it's going to cut off but more like the timing is off just a bit. I'm sure it's not that just what it feels like. The only code showing is 71.
I would try and isolate one problem at a time. You know you have something throwing the "71", so deal with that first. You mention lots of miles on the rig, but don't say how many. Personally, I replaced all but the temp sensor when I tackled the 71, but I also had everything apart to have the injectors serviced at the same time.
As for EGR parts, vacuum actuators are fairly common replacement item as are VSV's, but, and correct me fellas if I am wrong, I don't remember too many folks having their EGR valve totally fail on them. Plugged up a bit, but not out of commission. If you don't want to just replace all the EGR system, use the diagnostics in the FSM and the write-up linked above and try and figure out what the culprit is, then go from there.
IIRC, and it was a while ago, vacuum actuators today are probably about $50, VSV's are maybe $70 and EGR valves are $115.
Regardless of what you find, I would also get several feet of Toyota vacuum line and replace all you can reach. Vac line is cheap and easy.
After you get the 71 cleared, then maybe do a full tune-up, if that hasn't been done in a while. In my mind, this would include O2 sensors (every 75k miles and 100k for sure), plugs, cap and rotor, fuel and air filters, maybe even plug wires. Really clean the throttle body, run some good injector cleaner (my favorite is Red Line Fuel System Cleaner). Then see how she runs. But that is more than you wanted to know.
R.
Clean the TB, it's cheap and easy. While you have everything apart inspect the intake hose for cracks between the ribs. Both a dirty TB and cracked hose will cause your idle issue.
Clean the egr temp sensor. Inspect the EGR mod. Both can be done without removing anything else.
While you have the TB off remove the EGR VSV and check the resistance. '94 should be 30-34 ohms.
My 94 Code 71
https://forum.ih8mud.com/80-series-tech/115298-egr-code-71-1994-fzj80-cleaning-temp-sensor.html
My 94 Code 71
New intake hose since old one did have a crack. Other stuff you say I will check out.
R.
I did state the mileage at 205K but it could have easily been over looked where I put it. The stuff you say needs to be replaced would probably make it run a lot better since I don't really know when the last tune up was performed for sure. The owner said they did a tune up right before I bought it in Oct. of 07. Thanks.
