MoJ
Moderator
Taking tarbe's advice from the outing at Flat Nasty a few weeks ago I decided to clean the EGR temp sensor in hopes of resolving my CEL code 71. The temp sensor isn't as accessible on a 1994 as it is on 1995+. It's tucked under the EGR valve and is held by a 14mm nut. IIRC this is only applicable to all 1994's and California 93's as Non-CA 93's didn't have a temp sensor (someone correct me if I'm wrong).
(If you're confused which is the egr modulator and which is the valve they're labeled on the vacuum diagram under the hood.)
Getting to it is a little tricky. First remove the EGR modulator by slipping off the hoses and pulling it from the bracket. Second remove the bracket itself (one bolt). Next unplug the temp sensor and then figure out how to get a wrench on the 14mm nut. I used a stubby open end as the nut was positioned so that I otherwise couldn't get on it. Pull out the sensor and clean the tip with a wire brush or steel wool. Replace it all and pull the EFI fuse for a minute or two to reset the ECU.
So far I've gone through 4 start/run cycles of 10 miles each while traveling over 60 mph and the CEL has not returned. Prior to this it quickly returned each time after resetting the ECU so I've got my fingers crossed. As much carbon as it had on it I'm confident it couldn't of been working.
BEFORE
AFTER
BEFORE
AFTER
