94 Cruiser Code 71. PO replaced the EGR about 2 thousand miles ago. When I removed and examined the vacuum modulator I noticed a very black spot on the underside of the filter directly about the hole which I assume vents the area above the large diaphragm in the bottom of the modulator. My belief is that this dark spot is carbon from exhaust gases which should not in fact be venting from that hole, indicating that the diaphragm in the bottom of the modulator which separates the exhaust gases from the rest of the system has failed, hence replacement of the modulator is in order.
Can anyone confirm that this is a reasonable hypothesis? I realize that 'Code 71' is often a synonym for 'long challenging diagnostic process' but since the EGR has already been replaced, the only components left to be replaced in the system are the modulator, temp sensor or the VSV. Modulator is green topped and original with 138k miles as far as I know.
