- Joined
- Jun 9, 2005
- Threads
- 6
- Messages
- 101
As normal, it is pretty cold out here in Winterpeg (-35C). My code 71 has been consistently on and my biggest observation is that it takes longer for my truck to shift to 4th or overdrive even with the engine at running temp. Running longer at 3rd means bigger gas consumption.
My question: is code 71 a cause or an effect?
1. Is it a cause that it takes longer for my truck to shift to 4th? So if I get the EGR system fixed, the problem will be solved.
2. Is it an effect? Is it a result of my truck taking longer to shift to 4th so I should be looking at other factors like kickdown cables?
3. These are two different, unrelated scenarios.
When the temp improves to single digits, my CEL usually goes away. This will, probably, completely go away once winter is over like the last time. On the other hand, the CEL is lit up more this winter than previous so who knows. My EGR needs a working on, definitely.
My truck is a 94 with 173K miles on it.
My apologies if this has been brought up before. Appreciate any inputs you folks may give.
) the first time the truck is started & put into drive, the truck is sluggish to move. Drop the shifter to L , then back to D , and all is well.
