Code 7 07 seven TPS Throttle Position Sensor
MO
Ok, I have a code 7, which is the TPS circuit. The connection is good and corrosion free, and the engine performs the same as it did before. Gas mileage has remained the same over the past couple months that the CEL has been on as well. I reset the ecu to clear the code but it turned back on within 10 minutes of driving.
Where do I go from here? I was thinking that surely the TPS cant be bad because the performance and MPG hasnt suffered, but I could definitely be wrong.
There's a very easy on-board test of the TPS using a multimeter; procedure is outlined in the FSM.
I think there's a more detailed bench test, but the on-board one's still a good place to start.
Curtis
