code 26 after PM HG replacement
stouffville, ontario
hello 80 forum,
I just wanted to post my code 26 (rich mixture) issue after cylinder head gasket replacement. as with many of you, while I was in there, I re-routed the O2 sensor harness out from the trans tunnel as I was moving the O2 sensors to where the PAIR system mounted to the manifolds. I repaired some brittle insulation at injector 6 due to EGR heat, and deleted the EGR at this time. after repair I got the code, as well as a rough idle.
did the usual, check plugs, injectors , intake tube. all good.
check O2 sensor connections, clean out the dielectric grease I applied during repair. problem solved. turns out I killed the car with kindness.
I had read many threads regarding this code, with few resolutions posted so I hope this helps someone.
there are many reasons this code can come up, but this was mine.
What year is yours? I have a 94 and i can say that if you have a OBD1 your problem IS NOT the moving of the O2 or the EGR removal. I moved my O2 to the PAIR location and have no EGR for the last 20,000 miles with no codes at all. SO focus on other things. You still might want to check those changes for bad electrical connections or air leaks. But dont chalk it up to the O2 location or no EGRif you have a OBD1.
Edit: sorry i just read your post better. The problem was too much dielectric grease? That is interesting. From what i have read the grease should go on the OUTSIDE of the male plug to help seal the connection. Not in the electrical connection.
I originally had a code 26 which is what had me considering moving my O2 up to the PAIR area. I moved them and still got codes until i REALLY cleaned the O2 connections and put dielectric grease AROUND the plug. Ever since that no codes.
