Code 25 26 Rich Lean Air Fuel
I posted my concern on code 26 last month. After cleaning and almost spending alot of money on new oxygen sensors and EGR ports,etc I replaced my K&N for a Toyota OEM air filter and 1/2 day later no problems. NO irradict idling, stalling,etc. just an even idle. My guess the K&N oil is causing problems for the mass flow sensor .
IF YOU HAVE A K&N REPLACE IT.
hope this helps...
Chris
I ran a can of Toy FI cleaner and drove about 400mi this weekend with no CE.
Drove in town about 1 mi and the CE came on, its code 25.
The light stayed on untill the motor was turned off.
WHen restarted, no CE.
I have a TRD airfilter but have had it for about a year or so.
I will put in the paper filter and see what happens.
Replaced the OEM airfilter and reset the computer.
The wife says the CE light came on and stayed in for about 7min then turned off.
I was thinking it could be a dirty injector and was going to have them removed and cleaned.
But does this sound like a injector problem? Could a injector work most of the time and fail for a short time them work again?
It has new fuel pump, O2 sensors so you would think I could rule them out, maybe.
Under Trouble Area in FSM
Engine ground bolt loose
open in E1 circuit
injector
fuel line pressure
VAF meter
PAIR system
Heated O2 sensor circuits
Heated O2 sensor
Ignition system
ECM
What of these could cause a intermittent problem?
I had similar problems (sometimes) with my 88fj62 when I drove about 55 mph and up. My CE light light would stay on until I shut off the engine but retrieved the same codes. I changed the O2 sensors and never had that happen again.
I think that maybe the connectors got loose and/or burnt by laying on top of the exhaust system. Also check the terminals for corrosion. Try shaking the terminals while the car is idling and see if the CE light goes on. Just something to check on before other extensive work begins. I saw somebody's photo on this board of their O2 connectors being damaged by heat causing code problems. Where did you buy your O2 sensors and how many miles/months does the new ones have? Mine are over 2 years old and had the same connectors (no splicing) that I bought from oxygensensors.com.
Before spending any $$, try cleaning the MAF. If you were running a K&N, it may well be pretty dirty and oily.
FWIW, I had the same 25/26 rich lean code on my 94. Air filter was clean and OEM. Exactly the same symptoms you have, CE light on and off. It ended up being the injectors. Had them cleaned and it now runs like a swiss watch.
I will jinx my self posting this BUT...
I did a good amount of cleaning of the injectors and combustion chamber and NO MORE CE LIGHT
I used Toyota FI cleaner and SeaFoam in the gas and through the PCV hoses.
I don't know if it was a crabon or injector problem but all is well for now.
I guess I need to get some BG44K as it cleans both carbon and injectors.
K&N - MAF
hope this helps...
Chris
Interesting...I just bought a blown 96, and I am getting a 0171 code, which sounds like a MAF problem. First question is does anyone have a pic of the MAF? I am waiting for the FSM to get here. :) 2nd question is about the K&N. It has one, but does not look like a typical K&N install, looks like a K&N filter stuck on the end of the stock air intake. Would the better air flow be better for the blower? Or should I replace with an OEM air filter/intake? Where would I be able to find one? Thanks!
Timm the newbie
Timm the newbie
A lot of people have tried K&N for their cruiser and hated it. I run the stock paper one now and am looking to upgrade. I have a friend who has used K&N in his 91' for a few years and hasn't had problems with it, I jacked it once and noticed a slight improvement in performance but I'm due for a replacement. I wouldn't use it after I've seen a lot of people with cruisers take them out and return to the paper one. I'm still reasearching on which one I want to upgrade too or just go OEM again.
I have/had the TRD filter(like K&N filter) on the 80 and the 62.
I found no change in either vehicle when I changed from OEM paper to TRD filter and back to paper.
Now that I am in the dusty West, I will use the paper filter as the oiled has holes that you can see light through when you look through it into a light.
The oil is what does the filtering and if the filter gets dry, you will let dust through it.
I only ran the oilded filter where it was no very dusty. My next OEM filter will be the warshable OEM 'paper'(?) filter.
I no longer am getting both codes at same time but now had Code 26 yesterday and Code 25 today.
I was getting the both off and on, then they would go away. They came back but went away when I replaced wires, plugs and cap.
After about a month of no codes, I am getting codes but not at same time or I am checking the codes before both can be logged.
I am guessing the injector/s are sticking open and closed????
I have used fuel cleaner but maybe I need to have them cleaned by shop.
Don't want to take a chance with the injector wires so I don't think I will remove the injectors to have them cleaned.
