Code "24"
OK I think I have it.
---------Not sure why but I can not attach pictures right now. I got them in in the gallery under 1991 FJ80. Read this then check out the pics...let me know what you think.----------------I think I got it figured out! Hopefully. SO.... it was a fuel problem. I was doinking around with the contacts and noticed when in the "on" position if I touched 2 contacts together (yellow in the pic) I could hear the injectors. So I put a little foam block in the AFM so that the contacts would touch all the time. I cranked the engine and it started and stayed running. So next I gently bent the right contact over so that it would make contact with the left when the blue arm (sorry dont know the official name) moved to the right (which it does when the engine is running). I started it up and it ran just fine.I have no idea how it got bent...or if it really even was, maybe I just screwed it up more. What do you think? Did I actually solve it or just screw it up in a way that makes it run?
In that case I definitely think it would have failed the test I mentioned in post #19.
Sounds like you've fixed it, I guess. :shrug:
Cheers/congrat's,
Curtis
it would have failed for sure, Would have gotten there eventually if I would not have accidentally fixed it. I second your shrug.Thanks for the help all. I really appreciate it. This really is a great resource! Hope I can return the favor some day.
