Code 22 Question
Middle Georgia
How does this code relate to cold start issues? Would the water temp sensor fault cause cold Start issues at any outdoor temp? (Which is the problem I have)
Relaced water temp sensor with a new one. Power is good to the sensor. Still have the cold start issue and still showing the code 22 after clearing the codes. Any thoughts or helps is greatly appreciated. Thanks!
There is two sensor one for gauge and one for ecm which one did you change
Cool your after the third one back I think it has green plug just to right of oil filter 19mm deep socket on it and keep the brass washer or get new one comes with it from toyota
I see it and actually didn't see it until you mentioned it. Thanks again! This should solve the issue
