Clutch problems!
Ohio
I had the cruiser out yesterday ('77 FJ40) and the clutch pedal wasn't engaging until it was almost to the floor. I don't have any grinding, just a low pedal. I checked the slave cylinder and didn't see any seepage. Could the master be the culprit? I'm not losing any fluid out of the reservoir either.
Slave cylinder
Well I tried pumping up the clutch pedal and fluid began to leak out of the rubber boot on the slave cylinder. Anything I should know before replacing it? Is it a pretty straight forward bolt in and bleed? Thanks!
I know my clutch master is not original to the crusier because there wasn't any paint left on my drivers side floor board when I bought it a few years back. Do you really think I should replace it now? I have no idea when the p.o. replaced it (or rebuilt it) Thanks!
They almost always go out in tandem. I'd also just do 'em both and be done with it.
